585,975 active members*
4,806 visitors online*
Results 1 to 8 of 8
    May 2006
    Masterwood Project 317
    We upgraded our controler from cn10 to cn12 and had to upgrade cadcode, keep getting an error at the machine mw310 error. Does anyone have the machine specs or the configuration file from cadcode that works. we are using cadcode7. Thanks!
    From Padsmore
    Where are you guy?
    Apr 2009
    22
    Quote Originally Posted by joesmyname View Post
    __________________________________________________ ____
    Hi Joe
    I cant help you because i have a 320 with CN10 and mw309, but i am curious about the reason for someone to upgrade to CN12 and go to mw310, is it so big difference?
    Have you contact with Masterwood to find the controler and CN12 because a friend of mine needs to upgrade his CN6 in a quite old 302 (i think), and he doesnt now if it worth the cost for he's old machine.
    Apr 2010
    Hello
    Joe
    I'm a new member to CNC Zone I have been working on Masterwood machine for 9 years you can contact me at lrhtecser.com
    lrhtec
    Jun 2010
    can i turn on wood master with out compiuter conected?
    Jun 2010
    51
    I have masterwood 313 if any one want information about this model i could help.
    Aug 2013
    Do you hava a manual that you can send to me? I have a 309 and no manual it gives now an error.
    Have you to a complet copy of the software on the harddrive of the 313? I like to have that to.
    Thanks -> [email protected]
    Aug 2019
    Good day.Is the 313 similar to the 317?
    I have a Masterwood Project 317.I need to reset the head
    To zero for the xyz axis.Is there a technical manual available
    please?parameters?any information would be very much
    appreciated.
    Thank you
    Memo
  1. Masterwood Project 319-323
    By Tarpin in forum Commercial CNC Wood Routers
    Last Post: 01-28-2022, 08:38 PM
  2. Masterwood Project 313
    By 9thraven in forum CNC Machining Centers
    Last Post: 02-28-2018, 04:46 PM
  3. Masterwood Project 317 & 327
    By zedodia in forum Commercial CNC Wood Routers
    Last Post: 06-10-2014, 11:59 AM
  4. Masterwood Project 323
    By Famous in forum Commercial CNC Wood Routers
    Last Post: 01-29-2011, 03:21 AM
  5. Masterwood Project 327
    By cure1 in forum Commercial CNC Wood Routers
    Last Post: 04-18-2010, 09:13 PM
