585,937 active members*
3,999 visitors online*
    Masterwood Retrofit
    Hello,
    i put a scheme of what i want to do :
    I bougth a piece of card (Z80, CPU683 68EC020 PLC Tecnos system and input / output) for upgrade my cnc Master Project 323 who's working correctely with his old system under Dos ... but not very easy to use
    These cards was working into a Masterwood Project 309 retrofitted
    I replace old card (68000 named 681) by 683
    and Z80 Si_89 by Si_96
    I wonder if someone could help me to introduce good parameter to make it working ?
    Regards, GLP
    Re: Masterwood Retrofit
    Hello,
    some photos of retrofit of the Masterwood :
    this new CPU3-2M CPU68EC020-2003-01 (31SFC104640) card
    will replace the older CPU1 (68000) KTC91
    new old
    The old I/O cards (ACCTC90/02) will be replaced by new I/O cards 61SFA300101 (ASSI_CC_2007_01)
    The communication interface Si2.5 is replaced too by SFS10150 SI_96_01 (31SFS101460)
    and RamDisk Card is suppressed because no need anymore
    the software MasterWork drive everything
    To be followed
  1. MasterWood 365 5axis - Masterwood Opinions
    By zedodia in forum Commercial CNC Wood Routers
    Last Post: 03-05-2024, 03:13 PM
  2. Masterwood 317
    By WWWOODMAN in forum CNC Machining Centers
    Last Post: 02-12-2020, 12:44 AM
  3. masterwood
    By gcc in forum Commercial CNC Wood Routers
    Last Post: 08-12-2013, 01:31 PM
  4. Masterwood Speedy 315
    By Mike-CIW in forum CNC Machining Centers
    Last Post: 07-21-2009, 03:13 AM
  5. Replies: 31
    Last Post: 11-27-2008, 06:55 AM
