504,219 active members
4,841 visitors online
    Junior Member
    Apr 2006
    500
    Masterwood unload workpiece management
    I wish to unload a work piece midway through a program and turn it over to route the other side. I need stop the vacuum and raise stops and panel lifter, then continue the program once reloaded with vac on stop and panel lifter down.
    I have multiple processes processes going on both sides and by using 1 program I can ease usability and reduce human error.
    Many thanks in advance.
    Jun 2014
    80
    Re: Masterwood unload workpiece management
    If your running an old Masterwood, your best option would be to split the code with an 'IF' statement.
    #100=0 (front=0, back=1)
    IF #100=0
    (insert front half of code)
    IF #100=1
    (insert back half of code)
    You can switch the vacuum on/off manually, but I dont think you can engage stops or lifters while a program is running.
  1. MasterWood 365 5axis - Masterwood Opinions
    By zedodia in forum Commercial CNC Wood Routers
    Last Post: 03-28-2019, 07:19 PM
  2. Tool Load/Unload Jammed
    By scurr in forum Siemens Sinumerik CNC controls
    Last Post: 11-13-2015, 07:13 AM
  3. Unload program from memory??
    By tonper in forum Fanuc
    Last Post: 11-02-2012, 10:41 AM
  4. can't unload PLC
    By Mausbär in forum SIEMENS > 840D/810D > TURNING
    Last Post: 10-07-2011, 12:39 PM
  5. problem with electrical unload!!! edm mitsubishi
    By victorcnc in forum General EDM Discussion
    Last Post: 12-26-2009, 06:04 PM
