585,761 active members*
4,033 visitors online*
IndustryArena Forum > Machinery Manual, Brochure / Photo Archives > Machinery Manuals / Brochures > Matsuura MC-710V Manuals and info on spindle lubrication?
Results 1 to 4 of 4
    Sep 2006
    I have just bought an old Matsuura MC-710V (Ram-Master 1) VMC with a Yasnac 3000G control (7 segment display only) from 1980.
    Unfortunately the manuals and schematics are missing and I'm wondering if anyone happens to have scanned copies? I have found manuals for the MC-510V, but at least the spindle, tool changer and the control cabinets are different.
    Before I start testing, does anyone have information on spindle lubrication? What kind of oil and is there anything special to consider? Also the procedure for removing air from the hydraulic system is of interest.
    I do have the parameters if anyone needs a copy.
    Regards,
    Matias
    Apr 2012
    85
    Re: Matsuura MC-710V Manuals and info on spindle lubrication?
    -hh
    The phase rotation should be set to CW at the main breaker - there is a phase reversal check relay in the cabinet that will not allow the machine to be powered on if it is not CW.
    Any attempt to bypass the circuit and the power is applied will cause the spindle lubrication pump to run backward and flood the main spindle bearing with lubricating oil.
    The spindle lubrication is Mobile Velocite 6, or another VG 10 oil. The lubrication level should be checked/adjusted only when the main breaker is in the "OFF" position and fill to the line on the sight glass on the right hand side of the headstock after waiting a few minutes.
    If the machine is equipped with an oil cooler there is a reservoir attached that only holds a few liters.
    Too much oil will flood and wash out the grease from the spindle bearing.
    Sep 2006
    freakycnc
    Perfect, thank you!
    Feb 2011
    Hello
    I have a matsuura mc-510v and i lost all the parameter can you sent me a copy of parametres and the manuel
    Please help me
    My email :[email protected]
    Regards
  1. Matsuura 710V Yasnac 3000G not Zeroing
    By blakemachine in forum Uncategorised MetalWorking Machines
    Last Post: 01-01-2012, 07:23 PM
  2. matsuura 710V - spindle and axis drive oil type?
    By ca434sbc4 in forum MetalWork Discussion
    Last Post: 06-24-2011, 10:41 PM
  3. Matsuura 710V-2 Permaters
    By willysman in forum DNC Problems and Solutions
    Last Post: 11-20-2009, 08:58 PM
  4. Matsuura 710V 1980 ish
    By camaru in forum Uncategorised MetalWorking Machines
    Last Post: 11-09-2007, 05:28 AM
  5. Cheap ebay- MATSUURA MC-710V
    By davo727 in forum Knee Vertical Mills
    Last Post: 05-03-2007, 05:10 AM
