544,147 active members*
1,632 visitors online*
    Aug 2010
    177
    maximum feed rate - sinumerik 840D control
    is there a parameter i can change to set the maximum feed rate accepted by the control?
    need to cut a thread with a 6" lead......
    thanks in advance.
    Sep 2002
    1637
    Re: maximum feed rate - sinumerik 840D control
    I don't think that you can increase the max. feed rate of your machine by just changing a machine parameter. That rather would require more powerfull drives.
    Why do you think that the max velocity of your machine has been reduced unnecessarily during initial setting up?
  1. Need help ! Feed Rate Doesn't Remain constant in Siemens 840D SL 5-axis
    By reezal in forum SIEMENS Sinumerik CNC controls
    Last Post: 08-05-2019, 03:00 PM
  2. SIEMENS SINUMERIK 840D CNC CONTROL - Error Code 700042
    By zeshan in forum Machinery Manuals / Brochures
    Last Post: 03-23-2018, 09:55 AM
  3. CNC STAR ECAS 32T with Sinumerik 840D control, Alarm 66073
    By Mircea123 in forum CNC Swiss Screw Machines
    Last Post: 09-09-2016, 12:38 AM
  4. sinumerik 840d control
    By kevinwd1 in forum SIEMENS Sinumerik CNC controls
    Last Post: 01-22-2016, 09:16 AM
  5. maximum feed rate question
    By george w in forum Mach Mill
    Last Post: 03-05-2009, 12:09 AM
