589,272 active members*
5,203 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Maxxturn 65 with Fanuc 18i - Looking for the Zero/Index pulse for the Turret Encoder.
    Good day all,
    Maxxturn 65 lathe. (older model).
    Fanuc 18i controller.
    Please can someone assist me. I am trying to finish the installation of the multi-tool turret after it was removed for repairs. I get to the point in the steps where it says " Rotate tool disk (1) further until the zero pulse is detected at the rotary encoder". I have struggled to find this zero pulse marker in the Fanuc. I have looked all over to find the encoder pulse count, or a 0/1 indicator in the I/O pages, but all I can find are the servo/axis encoder counters for XYZUWC etc. This turret is assigned as a spindle and not an servo/axis.
    I would be grateful for any assistance.
    Kind regards,
    Trevor
    Aug 2007
    814
    Quote Originally Posted by TrevorMcCormack View Post
    Good day all,
    Kind regards,
    Trevor
    On my Cincinnati with duplomatic turret I use oscilloscope. Manual says do it by this way
    Apr 2009
    1384
    Re: Maxxturn 65 with Fanuc 18i - Looking for the Zero/Index pulse for the Turret Enco
    To guhl: you have oscilloscopes in Russia?...(joke)
    Depending on whether the turret encoder is brought in as an axis/spindle or is plc controlled, you may not see the index pulse on the display. The electrical diagram should clarify this.
  1. help:alarm 480&487 for emco maxxturn 65 fanuc 18i
    By samirabaza in forum EMCO Lathe
    Last Post: 06-02-2015, 04:08 PM
  2. Replies: 0
    Last Post: 02-13-2014, 09:46 AM
  3. Replies: 2
    Last Post: 09-16-2013, 08:08 PM
  4. Homing using limit and encoder index pulse?
    By purple_jeep in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-09-2013, 06:09 PM
  5. Fanuc 18i Turret Index limitation? (need help)
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-04-2007, 02:14 AM
