589,388 active members*
7,327 visitors online*
    Apr 2018
    mazak 218 chuck not selected
    Hi
    I have a Mazak SQT 30MS, lost the parameters, input them manually, and have an alarm 218 chuck not selected.
    Have played with switch on the side,select type internal/external and the opening /closing but no Joy.
    Is there a parameter I need to change to state it is a collet chuck? Changed R49 to add a "1" , I am sure this is for bar feed open /close.Do not I need to change any others..
    Any assistance greatly apprecaited
    Mike
    Jan 2011
    5
    Re: mazak 218 chuck not selected
    hello
    I have the same problem as you, how did you solve the problem
  1. Mazak qt15 sub Chuck problem
    By bmwfund in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-15-2018, 02:43 AM
  2. Mazak SQT 10MS - alarm 218 chucking type not selected
    By RRaly in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-11-2016, 03:48 PM
  3. Mazak 331: Misopearation No. 2 (chuck)
    By leiryll in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-06-2015, 01:14 PM
  4. Mazak ATC 30 Changing Chuck
    By BetaBob in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-28-2013, 11:34 AM
  5. Chuck Jaw Setup Mazak Fusion 640 T need help
    By Shotout in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-28-2006, 02:17 AM
