585,663 active members*
3,042 visitors online*
    Jul 2018
    Mazak 306 ATC arm driven alarm
    Mazak HCN 5000-2 having alarm of ATC arm driven alarm 306, I checked ATC motor all connection, megger test also performed, seems ok, in Auto cycle after 4/5 tools change , alarm comes and not resetting, tried to off/on machine, still not working...
    Help me out with the best please, it is driven alarm, this is 100 drive, I don't have new or alternate drive at this time,
    Help me with the best....
    Attached Thumbnails Attached Thumbnails 15317873888121847808361.jpg   15317874155811712236249.jpg
    Sep 2017
    139
    Re: Mazak 306 ATC arm driven alarm
    Please share the full alarm details.
    Please check at Diagnosis ==> Alarm.. The alarm codes mentioned within the brackets will give the exact alarm reason
    Or please check the 7 segment led indication on drive.
    Or please open the MR-J2 software from start menu and check the diagnosis ==> Alarm details
    Apr 2019
    Quote Originally Posted by navinbhas View Post
    I have the same problem in MR-J2CT the alarm is
    Z70.0002ABS REFERENCE POINT DISAPPEARANCE
    M01.0004 External Interlock
  1. Mazak MYSTERY. HOW do you clear this ANNOYING Mazak alarm??!!! NOBODY KNOWS!!
    By Mill&Lathe in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2022, 01:55 AM
  2. Mazak QT-10 T2 manuals --acct w/ mazak?
    By CDTINC in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-21-2012, 05:09 AM
  3. Mazak 6pc with machine Mazak 400n
    By anva in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-17-2010, 08:30 AM
  4. Mazak H-15
    By Karsue in forum Australia, New Zealand Club House
    Last Post: 02-16-2010, 04:12 AM
  5. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
