528,075 active members*
2,519 visitors online*
Results 1 to 4 of 4
    Junior Member
    Jun 2015
    4
    Exclamation Mazak AJV18 - M19 wrong orientation
    hi guys.
    i have a mazak M32A - ajv18 machine.
    after hard reset - some parameters has lost ot not up to date.
    i have a problem with tool changer. when we run M19 command we are getting wrong angle and the spindle hits the atc ARM.
    IT SEEMS THAT the M19 has wrong orientation , - and need to change in 90 degree more to get into the arm.
    any ideas? please see images, where is the orientation parameter code?
    thanks for the help.
    Junior Member
    Jun 2015
    4
    Any Ideas?
    please make a suggestions.
    thanks!
    Re: Mazak AJV18 - M19 wrong orientation
    Quote Originally Posted by avicohen View Post
    Any Ideas?
    thanks!
    Try parameter J 87, it is spindle orientation. Increase or decrease the value, and do a tool change cycle with to much care. One unit it is one degree.
    Hi I have a mazak ajv,18
    I have lost all parameters. Now it's OK but still missing. Macros of the probe
    Can u help me?
    Enviado do meu EML-L29 através do Tapatalk
  1. Replies: 3
    Last Post: 07-19-2017, 09:16 AM
  2. Replies: 2
    Last Post: 03-02-2016, 09:10 PM
  3. CNC X, Y, and Z Orientation
    By Nitwit in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 07-18-2012, 10:30 PM
  4. ORIENTATION
    By dcutler35 in forum GibbsCAM
    Last Post: 06-13-2012, 12:40 AM
  5. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
