535,183 active members*
3,970 visitors online*
    Mar 2010
    3
    MAZAK HCN 6000 II Mazatrol MATRIX - ATC ????
    How to set ATC origin value!?
    We need a little experienced help, this seems to be a simple sequence but it's the first time we encounter.
    Drive MR-J2 A32 Rotary axis.....in alarm !?
    Can you give us some topics on mobile phone via whatsApp while we are beside the machine !!? Please.
    How to test operation mode !?
    Aug 2007
    779
    Re: MAZAK HCN 6000 II Mazatrol MATRIX - ATC ????
    this must be in maintenance manual for your machine
    should to be something like that
    Attached Files Attached Files
    Nov 2020
    5
    dont play with mrj2sw, if you dont know. Use first Mazatrol menus. guhl sends you some operation tips.
  1. Replies: 0
    Last Post: 11-12-2019, 12:01 AM
  2. Mazak VTC 300C ( Mazatrol Matrix Nexus NC) - Conical Hole
    By ShiZniT in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-19-2013, 04:01 PM
  3. How to run XC milling on Mazak Integrex Mazatrol Matrix
    By Riddersholm in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-19-2012, 08:44 AM
  4. Mazak integrex 200-IV mazatrol matrix alarm 1281
    By bor32 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-02-2010, 07:59 AM
  5. Macro for FIXTURE OFFSET (mazak variaxis mazatrol matrix)
    By NCexplorer in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-26-2010, 04:19 PM
