560,109 active members*
3,550 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mazak VTC-200B, Error: 22 Amplifier not equipped.
    Oct 2014
    For the last couple of months I've been having an issue with starting up the mill and getting work done. It takes a few restarts but eventually it powers on without the error. Usually that entails about an hour of lost time. I've been looking around for the resolution to this error and I've come across a similiar problem on a different Mazak machine where the problem is isolated to a DK-510 board. I have not been able to locate such a board on the VTC-200B mill. Does anybody know where the location of it is or whether it has a different name and how to get to it? This machine is equipped with the 640M Mazatrol console.
    Nov 2008
    43
    Re: Mazak VTC-200B, Error: 22 Amplifier not equipped.
    we had the same problem and the servo for the x axis was faulty. We send it to mitsubishi for repair, it was around $1200
    Oct 2014
    Sorry for the thread necro but I had forgotten to update on the resolution. The fix ended up being sending out drive unit for fixes of: bad cooling fan, leaky capacitors, and cleaning the board of corrosion. We didn't send it out to Mitsubishi but a local repair shop.
  1. Amplifier not equipped
    By Siddhant in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-16-2022, 07:41 PM
  2. Alarm 22: Amplifier not equipped
    By stephenag04 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-19-2020, 07:15 PM
  3. Alarm 22 Amplifier not equipped
    By CNCSurtr in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-18-2020, 02:06 PM
  4. Mazak SQT 10MS - Alarm 16 Amplifier not Equipped
    By mkalavitz in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-16-2014, 09:42 PM
  5. MAZAK VTC 200B II
    By ANZORRR! in forum European Club House
    Last Post: 07-05-2012, 07:26 PM
