589,390 active members*
7,652 visitors online*
Results 1 to 4 of 4
    May 2021
    25
    MAZATROL/MAZAK Option function table
    hi everyone , i have list the MAZATROL/MAZAK Option function table , anyone need the function , can connect me. support all series .
    001 , BASIC EIA , EIA/ISO
    002 , HIGH SMOOTHING CONTROL , ????????SSS???
    003 , SPIRAL , ?????
    004 , EIA 3D COMP. , ??????
    005 , ROTATION , ????
    006 , GEOMETRIC , ???????
    007 , SCALING , ??????
    008 , EXT-DATA I/O , ????????
    009 , MAZATROL 3D , ??????3D?????????
    010 , POLIGON MACHINING , ???????EIA?
    011 , HOB MACHINING , ???????EIA?
    012 , 5-PLANE , ??????
    013 , HIGH SPEED , ?????????????????Mazacc-3??
    014 , SHAPE COMP. , ???????????????(Mazacc-2D)
    015 , THREAD , ??????
    016 , SUB C-AXIS CONTROL , ?2????????
    017 , INVERSE TIME , ??????????
    018 , DYNAMIC COMP. , ????????
    019 , 3-D CO-OR ROT. , 3??????
    020 , AUTO TLM , ???????
    021 , POLAR COORDINATES INPUT , ?????(G122)
    022 , CAMPARISON STOP , ????
    023 , HV CNTR. , ??????
    024 , SYNC. CONT. , ??????
    025 , EIA CONVERSION , EIA/ISO????
    026 , SPLINE , ????????????EIA?
    027 , G54.1 , ?????????
    028 , SYNC. MILL TAPPING , ????????
    029 , GANTRY ROBOT CONTOL , ????????
    030 , FLASH TOOL , ??????????
    031 , INCH/MM CONVERT , ?????????????
    032 , ROT-AXIS SHARPE COMP , ???????
    033 , GOO SLOPE CONST. , G00??????
    034 , SCALE FEED BACK , ????????????X,Y,Z?
    035 , SUB SP. 1/1000 DEG. POSI. , ?2??????????1/10000??
    036 , VARIABLE 600SETS , ?????600?
    037 , SCALE F/B(A) , ????????????4,5,6?
    038 , CYLINDER , ??????????
    039 , SYNC. MAIN SP. TAPPING , ???????
    040 , SIMULTANEOUS 5-AXIS , EIA??5???
    041 , B AXIS CONTROL , B AXIS CONTROL
    042 , IC CARD RUNNING , IC????????
    043 , EIA HELICAL TAP CYCLE , EIA???????????
    044 , EIA PATTERN CYCLE , EIA???????????????
    045 , PROTOCALL B , ?????B?RS232C?
    046 , SHAPING , ????????
    047 , 2ND AUX FUNCTIONS , ?2???????????
    048 , NURBS INTERPORATION , NURBS??
    049 , TILTED WORKING PLANE , ?????
    050 , SP/ROT. PARA. ADJUST , ???????????
    051 , TABLE UNBALANCE DETECT , ????????
    052 , 5-AXIS TOOL COMP. , EIA??5?????????
    053 , AUTO PECKING , ?????????????
    054 , ETHERNET RUNNING , ??????????
    055 , TOOL CENTER POINT CONTROL , EIA??5???????????
    056 , THREAD START POINT COMP. , ??????????????
    057 , RE-THREAD , ?????
    058 , PROGRAM MEMORY EXPANSION , ????????8MB
    059 , LOWER TURRET MAZATROL , ??????????
    060 , MILL TURNING MAZATROL , ?????????
    061 , HIGH SPEED SYNC. TAPPING , HIGH SPEED SYNC. TAPPING
    062 , NC-5TH AXIS(FOR NEXUS only) , ??????5?
    063 , CT-5TH AXIS(FOR NEXUS only) , ??5???
    064 , PITCH ERROR COMP.(FOR NEXUS only) , ????????
    065 , LEAD ERR COMP.(FOR NEXUS only ) , ?????????
    066 , 5-AXIS TOOL LENGTH COMP. , ??????????
    067 , WORK HANDLING , ?????????????????
    068 , TAP RETRACTION , ???????????????
    069 , WORK POS. ERR. COMP. , ?????????
    070 , ,
    071 , SPINDLE ATTACHMENT , ?????????
    072 , ANGLE TOOL 5-PLANE , ???????????EIA/MAZ)
    073 , SPRINT , SPRINT
    074 , ,
    075 , VOLUMETRIC COMP. , ??????
    076 , CT-8TH AXIS , ??8???
    077 , 5-AXIS SPLINE , 5??????
    078 , CHOPPING , ??????
    079 , PINCH / Y-OFFSET TURNING , ??????/Y???
    080 , CT-14TH AXIS , ??14???
    Sep 2023
    25
    Re: MAZATROL/MAZAK Option function table
    Can I open it remotely?
    Dec 2014
    34
    What is #24 SYNC. CONT? Does this have anything to do with tapping? Can't get my M Plus to peck tap for some reason.
    Quote Originally Posted by ladall View Post
    Options are activated by loading a cryptographic key. This can be done remotely without any problems.
  1. HEIDENHAIN TNC Option function table
    By kelenew in forum HEIDENHAIN -> GENERIC
    Last Post: 07-02-2024, 07:36 AM
  2. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2021, 04:06 PM
  3. Purchased used Deco 20a with transmit function option
    By Jayman73 in forum CNC Swiss Screw Machines
    Last Post: 01-16-2019, 09:07 PM
  4. Merge function - climb or unconventional option?
    By countryguy in forum Dolphin CAD/CAM
    Last Post: 08-26-2014, 03:37 PM
  5. Mazatrol M32B DNC option
    By chippah in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-01-2008, 09:57 PM
