544,051 active members*
1,813 visitors online*
    Jul 2010
    60
    Mazatrol T1 CPU alarms
    I have a QT 20 T1 control with square turret. I am getting alarms. CPU 1 fault, CPU 3 fault, Cpu 5 fault, MCU fault and sometimes screen goes blank wit CPU DOWN. Sometimes it will run perfect for 3 or 4 hours but other times it will just not run. I have tried swapping first 2 boards with good machine with no change.
    Jul 2010
    60
    I have a scrap QT20 with disc turret. I took complete control unit from scrap machine, swapped chips on first board (the small one that sits on second board) and replaced faulty one. It now works fine.
    Aug 2017
    15
    Quote Originally Posted by murphyc1 View Post
    I have the same problem alarms, 3 F CPU1 FAULT, 5 F MCU FAULT and sometimes CPU DOWN, which card did you replace, sometimes it works fine for a few hours
    Attached Thumbnails Attached Thumbnails 16227599275545692416112255868153.jpg
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-20-2021, 06:44 PM
  2. Seiki-Seicos LII Bubble memory Alarms --- Help on recovering from alarms 104,144,105
    By AZTEXAN_MIMXII in forum Uncategorised MetalWorking Machines
    Last Post: 05-16-2013, 08:59 PM
  3. Sm1 well versed with mazatrol 640m or atleast ne mazatrol
    By naren1608 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-22-2010, 11:29 AM
  4. #105 & #163 alarms
    By Greg 24 in forum Haas Mills
    Last Post: 06-17-2008, 10:54 PM
  5. mazatrol cam m2 alarms
    By gasto in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-27-2007, 08:16 PM
