593,585 active members*
4,705 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > MC4VAE 2561 RS232C ready interrupt time out error
Results 1 to 15 of 15
    Jun 2020
    68
    can't transfer the program from PC to mc4va, can you help me????? ,
    in photo n2, I also tried from floppy 3.5. but I did not succeed..
    from the cnc to the pc it works
    Aug 2011
    441
    Re: MC4VAE 2561 RS232C ready interrupt time out error
    is it work?
    DIR FD0:
    "Imagination is more important than knowledge."
    Jun 2020
    68
    I managed to copy the files from the mc4vae floppy drive, I had non-working floppy disks, or changed the floppy disks and now it works,
    while the connection through the 232 cable still does not work, I have opened the plugs of the cable and the connections are as in the hole, are they connected well?
    Mar 2007
    84
    Have You tried simply PIP ----> >R CN0: ----> press Write (or PIP ----> >R ----> press WRITE )?
    Jun 2020
    68
    I am attaching the photo again, I forgot to write 4 and 5 in db25, this morning I try as you say guntisk, but from many internet connections my cable lacks connect pin 1 of db9 to short circuit 4-6, this morning I add it and I try
    Aug 2011
    441
    Here is RS232 cable pinouts for 5000 series
    Attached Files Attached Files
    Jun 2020
    68
    I've tried both ways, but it doesn't work, thanks :-)
    Jun 2020
    68
    Quote Originally Posted by kurmay View Post
    thanks kurmay, my cable is the same as the pdf "RS232C_Setup", the number 1 was missing in db9 and i added it, but it doesn't work, i should build myself another cable like pdf "okuma osp5000".
    i think i will take this path, thanks
    - - - Updated - - -
    Quote Originally Posted by GuntisK View Post
    Mar 2007
    84
    Could You please share Your machine Optional Parameter (word) and (bit) screens? It could be parameter related trouble.
    From list of errors: 2561 RS232C ready interrupt time out means the interrupt ready and interruption have not been occured within a specified lenght of time with the DNC equipped with the DC code specification.
    Apr 2009
    1263
    Guntisk is spot on...your cable appears to now be correct, but unless the parameters are set correctly, it will output fine and still not upload. XON and XOFF must be working or it will fault going into the Okuma every time. Your jumper 4-5 is forcing you to use "DC code control" which it appears it is not using. Other settings matter as well for communication. 9600, Even, 7bits, 2 stop bits is what I typically use.
    Another important tip is that after you change your com settings and back them up, be sure to power off the machine including the breaker for about 2 minutes to let the com board properly reset and take in the new settings. If you are using the 5020 control as I suspect based on your pics, you may not have the backup key and will need to wait about 1.5 minutes before shutting down for all parameters to backup. If you watch the BC= as it cycles, it is a backup counter and as long as it makes a loop back to where it started after the parameter change, it will be backed up.
    Experience is what you get just after you needed it.
    Jun 2020
    68
    here are the parameters, thanks
    Jun 2020
    68
    Quote Originally Posted by maxlopez View Post
    I finally solved it by changing the parameters and inserting in the program the sign of:%
    Optional Parameter Bit #1 - 0000 1011
    1.0 (Auto parity check: yes) 1 my is 1
    1.1 (ISO code: yes) 1 my is1
    1.2 (Tape vertical check: no) 0 my is 0
    1.3 (Delimiter %) 1 my is 0
    1.4 (Verify at read: no) 0 my is 0
    1.5 (Special code read: no) 0 my is 0
    1.6 (Special code alarm: no) 0 my is 1
    1.7 (Special code ignored: no 0 my is 0
    Program start: %
    Program end: %
    https://www.aggsoft.com/cnc-dnc/okum...a-osp-5000.htm
    Aug 2011
    441
    Congratulations
    Mar 2007
    84
    Congatulations. You see- usually problem could be solved just by changing bits. Somehow forgot about asking for special signs presence at the program start and end, but they are essential.
    Feb 2008
    15
    Hello ,I have Okuma MC4VA OSP5000 control
    No communication problems for 30 years until now .
    VIA RS232 cable .
    I can send Machine programs to PC no problem .
    Okuma will not receive programs from PC
    I purchased Micro DNC 2
    To transfer/send programs .
    No luck
    I was told RS232 connector uses 3 wires .
    ! wire is to send ( works )
    Another wire Receives data .
    Was suggested to me Board is bad M3/ 3.2 ?
  1. Replies: 7
    Last Post: 02-23-2024, 06:11 PM
  2. Replies: 2
    Last Post: 10-20-2021, 02:31 PM
  3. MV-65 Control MORIC-3Y (YASNAC MX3) Alarm 077 RS232C ERROR
    By Kittiwat in forum Mori Seiki Mills
    Last Post: 11-26-2013, 02:55 AM
  4. OSP 5020L on LC-30 "2561 Error" Help
    By TriumphMachine in forum Okuma
    Last Post: 03-23-2012, 09:31 PM
  5. 2561 Time Out Error
    By mbm in forum Okuma
    Last Post: 06-25-2011, 02:41 PM
