589,272 active members*
6,016 visitors online*
IndustryArena Forum > CAD Software > Logic Trace CNC/DXF > mechanical lift called a johnson bar
Results 1 to 1 of 1
    Oct 2007
    1041
    made up my own johnson bar after seeing an antique one, it will lift amazing weight
    Attached Thumbnails Attached Thumbnails picture 1.jpg   picture 4.jpg   picture3.jpg
    Apr 2004
    5770
    Re: mechanical lift called a johnson bar
    Usually you need a couple of them to move a heavy object, like a machine. It's not used like a hand truck.
    Andrew Werby
    Website
    Oct 2007
    1041
    I do use it that way, I have 2 of those car haulers and then the johnson bar and push around like a trike
    I use this a lot around heavy machines , like my planer too
    Apr 2018
    143
    There is a variant of this tool intended for 'manual' moving of railroad cars.
    Page link: https://rrtools.com/product-category...oad-car-mover/
    Obviously, its slow, as each 'lift' only moves the rail car a few inches. Years ago a friend of mine worked summers at a small rural grain elevator and used this tool to move empty and full rail cars as each was filled.
    Oct 2007
    1041
    its amazing what can be done by hand but the cost is high
    and a few years back I saw one of these johnson bars as an antique and was expensive
    easily made, long handle and works well , a must for a shop
