any body know the pinouts for the start stop switch? I'm thinking of switching my machines to xp, unless things have changed you have to have a start stop switch to interrupt the run in xp.
It depends on what type of controller and card you have.
http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
Pplug, you are absolutely right I use the pci 400 cards with the riser card on my 4 axis and w/o on my three axis,
if you had the regular LC control box I could help you. Although heres where I found out what pins are for the probe on the aux connector in my controller.... First I loaded the free probing software. Next, I went to the diagnostic section in the probe settings panel. I then proceeded to see where the probe was supposed to be connected by shorting ground to the pins. I think an e-stop can be wired in this way.
Commandline switch to start and stop server:
cerberus.exe /start starts ftp server
cerberus.exe /stop stops ftp server
Regards
JMG
