547,544 active members*
776 visitors online*
    May 2010
    6
    Meldas L3 Ladder edit
    Hi everyone,
    We have a knuth numturn 400 with meldas l3 control in it.
    I want to edit the ladder circuit, but I can't find where the onboard edit can be enabled.
    The reason is to make an X/Z switch for the handwheel, because it can be change just in the PLC-SW setup and it's very frustrating.
    The switch is working (electronically), I can see the PLC signal in the diagnostic screen, the next step is to change the ladder, but it show a "not write" message.
    I searched the whole internet (maybe not the whole, but big part of it ) and didn't find a solution.
    I can program PLC ladders so it won't be a problem. I found the coils and devices, saved it via com port, downloaded the whole ladder circuit from the machine, I also wrote the necessary program part on paper. I have everything I need except this little thing... I can't edit the ladder.
    If someone have any information about this, it would be very appreciated. (Mostly with words, but with really nice words ).
    If not a complete solution, but some hints that may help, that would be good too.
    Thank you
    Jul 2021
    Hi
    Did u find a way to do this? I need the same too, it can be great thing if u can help me im really in need
  1. Edit Sharp Ladder Logic
    By Jet A in forum Sharp CNC
    Last Post: 12-11-2012, 09:26 PM
  2. Mazak Matrix Ladder view edit.
    By hutch07 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-15-2011, 06:00 PM
  3. Fanuc ladder edit problem
    By Dave3891 in forum Fanuc
    Last Post: 01-20-2011, 12:19 PM
