593,589 active members*
4,836 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Meldas M65 run programs from IC Card (FCU6-EP203-1 / HR831A+HR832)
    Jun 2021
    16
    does anyone know how programs can be run directly from an IC Card?
    I set up an FTP server (pure-ftpd) on my computer and I can transfer programs via the Meldas M65 terminal to the IC Card, afterwards all I can do seems to transfer the NC program from the IC card to the NC system and run it.
    There are a few problems here, the internal NC system memory is very limited, while the IC card has 2 GB..
    Jun 2021
    16
    Re: Meldas M65 run programs from IC Card (FCU6-EP203-1 / HR831A+HR832)
    Everything fixed on our side, it works well with our Meldas M65 CNC
  1. Run Multiple Programs off Flash Card
    By mcCNCfl in forum Fanuc
    Last Post: 10-26-2023, 09:13 AM
  2. Meldas m65
    By dh08td in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-21-2020, 04:53 PM
  3. Mitsubishi Meldas M65 tool change problem
    By tbilecen in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-20-2010, 12:23 AM
  4. Programs on PCMCIA card
    By Topr in forum Fanuc
    Last Post: 08-07-2009, 02:44 PM
  5. MITSUBSHI FCU6-DUN22 DISPLY PROBLEM
    By suresh patil in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-19-2008, 06:45 AM
