592,217 active members*
4,413 visitors online*
Results 1 to 11 of 11
    Dec 2009
    551
    Exclamation Memory Clear / Reset
    I am having a problem with communications for my machine. It is a Hitachi Seiki HT20SIII with Seicos L Multi control. I was told there is a way to clear the memory by pressing 2-3 buttons upon startup. Does anyone know how to do this? If you need more information see my other posts. I am still having the same problem.
    May 2009
    181
    what problems are you getting.. clearing memory probably wont help
    Dec 2009
    551
    Basically, someone hit emergency stop while i was sending a program to the machine. Now when I start the machine and go to the sned/recieve screen, all of the communication parameters are blank, all of the programs are gone, and once i am in that screen, no matter what button i push, the machine freezes up and I have to shut it down.
    May 2009
    181
    what kind of controller is this.. did u get a ps 101 alarm or something?
    Dec 2009
    551
    Its a Seicos Multi controller. And when I power up the machine, there are no errors at all. Everything functions a it should, which is odd. I cant imagine what the problem is
    Jun 2008
    1838
    Quote Originally Posted by shas595 View Post
    On my Fanuc controllers if the control is powered down for example E stop when the LSK/input is flashing on screen (ie loading a program) the parameters and programs are deleted so if as you say the parameters are blank that`s most likely what`s happened I think.
    Re-loading the Parameters (They were backed up somewhere???) should do the trick.
    Dec 2009
    551
    I got it solved. I had a guy come over and show me what to do. He adjusted some control knobs on the board in the back, did the memory reset, and set it up so it wont happen again. I tested it, and hit E-Stop while inputting, and nothing happened. So i am all set and don't have to worry about my clumsy friend. Why couldn't they do that in the first place???
    thanks for the help
    Jun 2019
    thanks for the help
    How did you fix this? I am having what seems like the same problem on a Hitachi Seiki HT25S with Seiki MULTI .
    Feb 2021
    Re: Memory Clear / Reset
    I think I´m having a similar problem, I was downloading a program in some point when the memory got fiiled someone unplug the cable and then the multi seicos got a legend that it couldn´t display the program because it was to big that I erase it, I erase everything and the message still comuing up, I set the selector in the rigth position "7" and erase the NC programs from the ACGC mode and still having the same issue, Do I need to erase another stuff in the ACGC mode? I didnt wan t to erase all the parameter and settings I can run in the YASNAC screens, and I will have the problem that my NC codes are to big for the memory.
    When I am in the memory mode and try to see the program the software kind a resets to the main screen"initial" shows again multi seicos version , don´t know if the OS got screw or something.
    Hope you can help me I see that you have kind a the same problems I will deeply appreciate it, thank you in advanced.
    Quote Originally Posted by Jonhyvan View Post
    Did anyone get rid of this problem?. I am here with same problem. I deleted nc programs but in F2 (program) whenever
    I try to see,edit or cycle the program. It freezes and i hav to shoutdown machine.
    If you solved problem please share.
    I Hope that it doesnt need to reset all parameters...
    Dec 2009
    551
    I sent you an email - you will have to reformat the memory area to get it to work again
    John
    Thanks on Email. I am Waiting another answer
    I would like to teach me how to make that. I am finiding answer on this problem a lot of time.
  1. FANUC 15M Memory all clear
    By david_chen in forum Fanuc
    Last Post: 12-16-2013, 03:09 PM
  2. DRO clear
    By ltran2000 in forum Dynomotion/Kflop/Kanalog
    Last Post: 09-04-2012, 06:30 AM
  3. Clear all memory of Fanuc 10MA
    Last Post: 07-11-2012, 09:22 AM
  4. Replies: 9
    Last Post: 02-28-2011, 04:30 PM
  5. FANUC MEMORY CLEAR & PRECAUTIONS
    By CHANDRU in forum Fanuc
    Last Post: 05-12-2009, 06:16 PM
