548,466 active members*
2,577 visitors online*
Thread: Memory size
Results 1 to 8 of 8
    Oct 2006
    154
    Memory size
    How do I tell how much memory my 1988 DC 4020 has?
    I am currently using a Calmotion USB to DNC programs- but DNC seems to have its own problems.
    So I was thinking of upgrading my memory so I could put the proofed / good programs into the machine memory.
    Thanks.
    Aug 2009
    1130
    Re: Memory size
    ...depends on your CPU 1400 board version number.... most likely 384k or less max upgrade in your case.
    https://www.cnczone.com/forums/fadal...y-88-88hs.html
    Calmo can be a little tricky to use (at 1st), but after the learning curve its maybe your best option.
    Type ME at the Command Line to view memory
    Oct 2006
    154
    Re: Memory size
    Attachment 471468
    Machinehop5 ,
    Thanks ! will start it up this afternoon and do the ME to see how much it has.
    I have attached a pic of the card.
    Thanks!
    Oct 2006
    154
    Re: Memory size
    I typed ME on the command line and it just listed that I have 58% free.
    Aug 2009
    1130
    Re: Memory size
    ...save all programs....delete all of them....then add a known size program...and commad ME again. then do the math
    Oct 2006
    154
    Re: Memory size
    Ahhhhh , sounds like a good plan.
    Thank you !
    Jan 2015
    414
    Re: Memory size
    So the 1040 card is the Mill interface card, not the memory card.
    If you have a extended memory card it is the 1460 card (the long one) attached to the 1400 card in slot 5. and if the sticker is still on it could tell you how muck memory. If all the chips spots are full depending on the version it would be 422k most likely.
    ME should say how much mem you have like in this picture.... Not sure if it tells you that if you do not have expanded memory.
    Oct 2006
    154
    Re: Memory size
    Thank you !
    Looks like I have 180K
    - - - Updated - - -
    Thank you !
  1. Increase memory size on R2E3?
    By cut more in forum Bridgeport / Hardinge Mills
    Last Post: 05-31-2008, 02:08 PM
  2. Memory size
    By cseng in forum Okuma
    Last Post: 04-30-2008, 12:48 AM
  3. Memory Size?
    By BluegrassPicker in forum Fanuc
    Last Post: 02-08-2008, 08:01 PM
  4. SL-65B with MF-T6 memory size?
    By BluegrassPicker in forum Mori Seiki lathes
    Last Post: 02-08-2008, 07:59 PM
  5. Memory size on VFO
    By krista in forum Haas Mills
    Last Post: 09-02-2004, 02:15 PM
