Optic laser Fiber Handheld Laser Welding Machine
This is 1000 watts Raycus fiber laser welding machine with a CW laser source. (1500W/2000W optional)
-Fast welding speed
-Perfect welding effect
-100,000 hours lifetime
-No any consumable part
The original:www.opticlaser.net
Model:
OPT-FW1000/1500/2000
Brand:
OPTIC
Applicable Model:
Fiber laser welding machine
Handheld Laser Welding Machine Specifications
Laser power 1000/1500/2000 watts
Laser source
Raycus / IPG
Welding head
Wobble welding head / Normal welding head
Laser frequency
50Hz-5000Hz
Adjustable power rate
5 to 100%
Beam quality 1.1
Electric power
220V50HZ / 380V 50Hz
Wavelength
1070±5nm
Consumable part
Protection lens, focusing lens nozzle
Fiber length
15m Standard
Cooling method
Water chiller
Dimension
930x600x800mm
Gross weight
200kg
Handheld Laser Welding Machine Fiber laser source
Raycus laser machine
Back of the Laser Machine
The third-generation single module CW fiber laser series developed by Raycus ranges from 300W to 2,000W,
the new lasers have higher electro-optical conversion efficiency, higher and more stable optical quality,
stronger altitude stress-resisting capacity and it applies optimized second-generation fiber transmission
system to ensure a more stable and more sophisticated cutting effect in thick sheet cutting. This machine
applies to many application scenarios: cutting, welding, holing, medical device processing, etc., with a
the narrow seam of the cut sheet and bright section. Compared with the same lasers, it has obvious advantages.
Welding head with wobble function.
Why need the wobble welding head for the fiber laser welding machine?
Head for fiber laser welding machine
The advantage of laser welding wobble head
1. The process that the conventional head can not complete, the dithering head only needs to use about
70% of the power, so that the cost of the laser can be saved;
2 Wobble welding back and forth through the galvanometer motor, so that the bubbles with large impurities
can reduce bubbles, frying, splashing, etc.
3 In the case of irregular gaps, the requirements for the fixture can be reduced.
The conventional oscillating head welding gap is generally 0.2 mm, and light exceeding this width directly
passes through. The width of the gap that can be welded by the oscillating head can reach 0.5mm,
but the conventional welding head can only be welded to 0.2mm. There is no galvanometer motor in
the welding head, so there is no swing. The welding effect is not good, the welding process is limited.
Safety Protection device for 1kw Fiber Handheld Laser Welding Machine
Safety Protection device for 1kw fiber handheld laser welding machine
The red part with black color is a protection device when the machine welding on metal.
If the safety device didn't clamp what do you weld metal, the laser power can not come.
So it has to clamp the metal as you welding that one. The laser power can come out.
Water chiller and laser source with inside one cabinet
Water chiller
Water chiller provides a good cooling system for the laser source and welding head. It can protect the source and
welding head working a long time per day. Maximum can up to 10 hours per day.
Also can help you save more layout space and shipping cost.
The complete fiber laser welding machine easy to move and one wood box
MachineFour-wheeled
