504,069 active members
5,856 visitors online
IndustryArena Forum > Events, Product Announcements Etc > Articles > METHODS MACHINE TOOLS INTRODUCES ITS OWN BRAND OF VERTICAL MACHINING CENTERS
Results 1 to 1 of 1
    Feb 2010
    50
    Sudbury, MA, U.S.A. (July 10th, 2019) – Methods Machine Tools, Inc., North America's foremost supplier of leading-edge precision machine tools and automation, has introduced a new line of Methods Branded 3-Axis Vertical and
    5-Axis Bridge Type Machining Centers, all engineered and built to Methods' highest specifications and quality standards. The Methods Machining Centers are available in North America, and offer an affordable, accurate and reliable best-in-class mid-range machining solution. Click Here for more information on Methods Machining Centers.
    "We are very pleased to announce the introduction of Methods Machining Centers," said Mr. Jerry Rex, President and CEO of Methods Machine Tools, Inc. "Methods' engineering team has ensured that our new branded line meets our customers' needs and expectations in North America. These machines will provide an ideal value-to-performance solution in the marketplace and complement our full portfolio of leading lines."
    Methods Machining Centers are made to Methods' design and engineering standards by Litz Hitech Corp., a reputable, well-established machine tool builder, and are fully backed by Methods industry-leading service and support. All Methods Machining Centers are fully inspected to meet strict quality and design specifications, and also be in compliance with ISO/ASME standards. Laser and ball bar testing ensures performance and accuracy of each machine.
    Methods 3-Axis Vertical Machining Centers include four initial models ? MV 800H, MV 1000H, MV 1100H and MV 1600H ? featuring a 15,000 RPM, 30 HP BIG-PLUS 40-taper Direct Drive Spindle with Oil-Air Lubrication and Spindle Oil Chiller, providing power, speed, superior surface finishing, long spindle life and thermal stability. Rigid box-way construction in the Z-axis utilizing Turcite B ensures exceptional cutting performance and machining accuracy. Turcite B technology was specifically developed to provide machines with superior rigidity, low friction coefficient, reduced vibration, excellent damping characteristics without stick-slip, as well as very high wear resistance for long machine life.
    Additional features in the Methods Vertical Machining Centers include thermal compensation using three
    thermocouples to allow the software to compensate for actual thermal growth. The MV 800H and MV 1000H have robust 1.378 inch (35mm) roller guideways in the X and Y-axis with 2,362 IPM rapids. The MV 1100H has a larger structure with 1.77 inch (45 mm) roller guideways in the X and Y-axis with a 1,890 IPM rapid rate, and its Z-axis box ways are over 3 inches wider (side-to-side) than the MV 800H and MV 1000H. The MV 1600H is a heavy-duty 41,888 lb. machine designed for exceptional cutting performance on large, diverse, complex parts. The MV 1600H has an impressive 21.85 inch distance between Z-axis box ways (side to side) and offers 2.17 inch (55 mm) roller guideways in the X and Y-axis with 1,417 IPM rapid rates. Automatic tool changers range from 24 tools to 40 tools, depending on the machine.
    Methods MB 650U 5-Axis Bridge Type Machining Center is designed for the high accuracy, 5-axis simultaneous machining of complex parts and significantly reduces the need for multiple setups. Equipped with standard linear scales on the X, Y, Z-axes, rotary scales on the B & C-axes, and thermal compensation results in stable, high precision part production. The MB 650U has a 15,000 RPM, 25 HP BIG-PLUS 40-taper Direct Drive Spindle with Oil-Air Lubrication and Spindle Oil Chiller for long spindle life. This performance package also includes a Calibration Ball, TCP Software, and Probe System for setting/calibrating precise tool center point. A Laser Tool Measurement System detects tool wear, damage, and breakage, reducing non-productive time and enabling automated operation.
    All Methods Machining Centers feature FANUC controls, the industry's benchmark for quality and reliability. Methods VMC's have the FANUC 0iMF Control with 10.4 inch LCD screen, manual guide I, AICC II, 2 m/ sec Block Processing Time (BPT) and 200 Block Look Ahead. For the highest level of performance and processing power required for complex 5-axis machining, the MB 650U Bridge Type Machining Center features the FANUC 31iMB5 Control with 15 inch TFT screen including a data server, manual guide I, AICC II, 1 MB of NC memory, .4ms BPT, 600 Block Look Ahead, Collision Detection (built in 3D interference check), Fast Package III, Ethernet and 2GB CF card.
    "We are confident that our new Methods Machining Centers will exceed customer expectations for quality, reliability, accuracy and longevity at a competitive price," said Jeff Ervay, Methods Brand Product Manager. “To meet the needs of our customers, we are continuing the development of the Methods product line with additional models in the future.”
    About Methods Machine Tools
    Methods Machine Tools, Inc., in operation since 1958, is North America’s foremost supplier of leading-edge precision machine tool and additive solutions – providing superior products, engineering and automation, parts and service, training, and integration. With over 350 employees, eight sales and technology centers, and over 40,000 machines installed throughout the United States, Canada and Mexico, Methods supplies leading-edge precision machine tools and solutions. For more information about Methods Machining Centers, please contact Jeff Ervay, Methods Product Manager at, EMAIL: [email]jervay@methodsmachine.com[/email] TEL: 978.443.5388, FAX: 978.440.9405 or visit [url=http://www.methodsmachine.com]Methods Machine Tools - Leading Edge Precision Machine Tools[/url].
  1. Replies: 0
    Last Post: 11-18-2016, 06:17 PM
  2. Replies: 0
    Last Post: 04-22-2015, 03:11 PM
  3. Replies: 0
    Last Post: 11-14-2014, 04:00 PM
  4. Replies: 0
    Last Post: 04-23-2014, 03:47 PM
  5. Replies: 0
    Last Post: 08-02-2011, 02:01 PM
