578,964 active members*
8,111 visitors online*
Results 1 to 5 of 5
    Apr 2012
    9
    MGP Pendant issue MK3+TNGv2
    Hello,
    This is a issue i first got about some years ago and due to no time and little use of the CNC have not been addressed before now.
    The issue happend after upgrading to a newer version of TNG in January 2018. not sure but when i press the button on the pendant and rotate the wheel the selected axis is only jogging back and forth.
    Not moving any way. I have added a video here: https://www.youtube.com/shorts/uPTHUqtOQ4Y
    i have the following setup.
    • MPG pendant with adapter Item# MPG
    • CNC USB controller Mk3 Item# MK3
    • Adapter for MPG pendant Item# ADMPG
    • USB cable - double shielded Item# USB
    Could anyone point me i the correct direction to fix this? i will upload the setup in 5-10min max
    Thanks, best regards
    Apr 2012
    9
    Re: MGP Pendant issue MK3+TNGv2
    Her is the setup attached.
    I have the latest TNGv2 downloaded from PlanetCNC site and i have updated the firmware today also
    Mar 2017
    1253
    Pendant is in step mode.
    Check Settings/Jogging/Handwheel page.
    Apr 2012
    9
    Quote Originally Posted by PlanetCNC View Post
    Hi
    I have tried now without stepmode. Its acting different but it still jogs back and forth when i move to the pendant in one direction.
    Is there a way to record the impulses to analyse the signal from the pendant?
    Mar 2013
    Quote Originally Posted by johjoa View Post
    Hi
    I hope that you have fixed the problem by now, but the symptoms suggest that you have lost one of the two signals from the MPG. The MPG generates X and Y pulses; with just one of these the software can detect MPG movement but not direction and the effect is exactly what you are seeing.
  1. [TNGv2] - Wireless handwheel (MPG pendant)
    By PlanetCNC in forum PlanetCNC
    Last Post: 02-01-2022, 06:41 PM
  2. PlanetCNC Controller Mk3 Spindle Motor Issue
    By Btdempsey1 in forum PlanetCNC
    Last Post: 06-25-2020, 03:55 PM
  3. New Mk3/4 controller kit build - Servo Issue
    By Zeusguy in forum PlanetCNC
    Last Post: 03-29-2020, 07:52 AM
  4. Replies: 1
    Last Post: 01-05-2020, 12:40 PM
  5. MK3/4 Axis Speed Issue
    By Designosaur in forum PlanetCNC
    Last Post: 10-21-2018, 11:04 AM
