567,395 active members*
3,592 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Mimaki ME-500 Data transfer
Results 1 to 5 of 5
    Feb 2019
    Hi, I'm not new to CNC zone, I've read through countless postings here but have never posted anything myself. I recently purchased an older Mimaki engraver/plotter. I've contacted Mimaki in Japan, and in the USA. I've also contacted several Mimaki dealers. It seems that it's past it support date by a large margin, so the only thing I received from anyone was an operation manual which I already have.
    My issue it sending data to the machine from my PC. I'm using a simple DNC program which sets the com, baud rate, parity, stop bits, and handshake settings. I'm using a 9-25 null modem serial cable to go from my PC to the machine. The machine is compatible with .nc and is also compatible with hp-gl. I have vcarve pro from vectric and it has a post processor that will output both formats of code. But when I go to send the file from the DNC program to the machine I get zero response.
    Any help in trying to solve how to send file to the engraver would be greatly appreciated.
    Thanks, Travis
    Jun 2009
    13
    Re: Mimaki ME-500 Data transfer
    Hi Travis,
    Got any hit on this?
    I have a ME-300 that I'm trying to put to work and would love to find some puzzle pieces too.
    I was able to make the machine move by using the Generic HP-GL post processor in VCarve and using the checkbox in "Output direct to machine".
    I never heard of DNC program before but in short I added a new printer and set the parameters you listed above manually.
    I'm sure I can find it if you need the info.
    I could only have it to work at one set height though (Z height is set in the controller) because HP-GL only give the command PD and PU to drive the Z axis.
    (PD and PU mean Pen Down and Pen Up)
    So with PD the machine goes to the set height and goes back up with PU... Let's say it's a bit limiting.
    I tried guessing a couple things in the command code to control the Z height but apart from the standard PD and PU nothing worked so far.
    I wish I could find information on MGL-iic3 command so I could finish writing the post processor for it!
    Every search I did seem to bring me back the numerous Mimaki flyers of their various machines.
    Their machines support the command code that no one seem to know about! :bsnuts)
    Hello,
    the Mimaki implementation of HPGL ("MGL-IIC3") has some extensions to control the Z-axis:
    use !PZ to set the Z-axis.With one parameter you set the down-position, with two parameters you can set down and up position. (units are always in 0.01mm)
    so e.g.
    !PZ-200;
    sets the down postion to -2mm on the next PD command.
    !PZ without parameters restores the up/down postitions to the values entered on the panel.
    other commands:
    !VZ (set moving speed vo Z axis)
    !MC (set spindle rotation)
    VS (set X/Y spindle speed in mm/s)
    hope that helps!
    Jun 2009
    13
    Hi boingboing,
    Thank you so much for the reply!
    I did not have the time to integrate and test it yet but I will let you know as soon as I do.
    Feb 2023
    Quote Originally Posted by get_f8 View Post
    Hi boingboing,
    Hello,
    I also have this machine.
    Did you manage to write a driver for it?
    Thanks in advance,
    Martin
  1. M plus eia data transfer
    By Dougw172 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-10-2014, 07:22 PM
  2. data transfer 332 - PC
    By Schmiddi in forum HEIDENHAIN -> TNC
    Last Post: 04-06-2012, 01:43 PM
  3. data transfer TNC 426 with LAN
    By jz1969 in forum HEIDENHAIN -> GENERIC
    Last Post: 10-15-2011, 04:04 PM
  4. Best way for data transfer?
    By pontiacg5 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-24-2010, 07:32 AM
  5. Data transfer in DOS
    By Schleiffan in forum Fanuc
    Last Post: 05-17-2008, 07:44 PM
