585,888 active members*
5,086 visitors online*
    Sep 2016
    8
    mits FX10K set-up wiring 1998 model... Help
    I bought a 1998 Mits FX10K from a company. I watched it run at the company. Unfortunately I was not the one who disconnected all the wire bundles. I have al but a few hooked up. There are 3 main connectors running to a drive in the cabinet op middle. They are marked but not the drive. I also have several small bundles that run to the terminal block in the cabinet under the side panel at the bottom. Does anyone have a wiring diagram, book or can someone take a few up close pics of these areas so I can see how the wires get hooked up.
    update- I got almost all of it figured out. I only have the 3 connectors left that are behind the door in the front of the main console.
    still would like to have a wiring diagram
    Feb 2009
    51
    Re: mits FX10K set-up wiring 1998 model... Help
    Those 3 connectors go on the Servo amplifier that is behind the panel on the right side of the controller, you probably already connected the motor output and tacho wires to the bottom of the unit. They go from left to right XE, YE, ZE.
    Sep 2016
    8
    Quote Originally Posted by Makrep View Post
    Great thanks a bunch!
  1. Busellato junior 60/4y, model 1998
    By Malacara in forum RFQ Feedback
    Last Post: 05-03-2017, 03:11 PM
  2. 1998 mighty comet mits 500
    By tedtmm in forum Mitsubishi controls
    Last Post: 06-02-2014, 01:01 PM
  3. Busellato junior 60/4y, model 1998
    By Malacara in forum Spanish
    Last Post: 03-06-2013, 09:20 PM
  4. mitsubishi fx10k chiller
    By moldman3 in forum EDM Discussion General Topics
    Last Post: 09-21-2011, 10:39 PM
  5. Mitsubishi FX10k vs. Charmilles 310 wire EDM
    By Alanstr in forum EDM Discussion General Topics
    Last Post: 04-20-2010, 07:51 PM
