544,157 active members*
2,951 visitors online*
IndustryArena Forum > CAM Software > Esprit > Mitsubishi edm wire help
Results 1 to 4 of 4
    Jan 2021
    10
    Hi guys, I am doing 4 axis programs for wire EDM for the first time! I think the profile and the technology are ok, the simulation and the XY and UV coordinates now seem correct to me by comparing them with the machine coordinates. when I export the program it doesn't create the geometry radius for me, I only have linear points, instead in the simulation it moves correctly.
    Inviato dal mio MI 8 utilizzando Tapatalk
    May 2021
    Re: Mitsubishi edm wire help
    Did you set the Z1 and Z5 value on the machine?
    Jan 2021
    10
    Z1 and Z5 are correct in esprit, the problem is that the post processor only gives me straight points when I create a 4 axis path. I managed to modify the U and V axes, I created a program with the points from U V instead of absolute coordinates of the U V axes, now I have to find the way to enable and disable the rays in 4 axes from the post processor
    May 2021
    Ok , just watch out because I had a problem where esprit would post what the Z1 and Z5 were supposed to be if the part was at table level, which was hardly ever the case and I would lose what value I had entered. I run with absolute U/V turned on under the Environment setting 1 page on a MV series machine. Will be the same on an FX machine. I'm just not sure where to find it.
    I can always take a look at your program if you like to see if I can notice anything.
  1. Mitsubishi Wire EDM
    By Roswell28 in forum General EDM Discussion
    Last Post: 05-28-2021, 06:09 AM
  2. Mitsubishi FX 10 wire EDM
    By LSI Innovations in forum General EDM Discussion
    Last Post: 02-25-2018, 07:44 AM
  3. Mitsubishi Fx 10 wire edm manuals
    By jesus rojas in forum Machinery Manuals / Brochures
    Last Post: 07-11-2016, 12:23 AM
  4. Mitsubishi Wire EDM
    By Roswell28 in forum Esprit
    Last Post: 12-04-2008, 05:14 PM
  5. Mitsubishi FA Series Wire EDM
    By supercrewed in forum General EDM Discussion
    Last Post: 08-20-2008, 03:21 PM
