601,652 active members*
2,479 visitors online*
    Oct 2023
    Exclamation Mitsubishi FA20S / 2010 p/y. u700 alarm.
    Hello I had problem with my FA20s from Mitsu.
    For now machine had u700 alarm and I can't do nothing with machine.
    Shortly before the failure, the machine started showing strange alarms such as:
    U828
    U823
    T215
    T101
    Has anyone encountered a similar issue? One thread on the forum mentions the voltage control board, but the question is— which board is it exactly, what is its name? If I had the name, I could remove it and take it to my friend, who's an electronics technician, to check the solder joints on the PCB.
    I’d appreciate any help or suggestions.
    Best regards!
    Re: Mitsubishi FA20S / 2010 p/y. u700 alarm.
    Quote Originally Posted by biciu123 View Post
    U828
    U823
    T215
    T101
    Best regards!
    The PCB board part number you are looking for should be like PSU-01, PSU-03, or something with PDU.
  1. Mitsubishi FX10K - U700 error
    By 4d53 in forum EDM Discussion General Topics
    Last Post: 04-28-2025, 12:36 AM
  2. Mits FA20S threading problem
    By DonaldJ in forum EDM Discussion General Topics
    Last Post: 12-14-2022, 05:26 PM
  3. Alarm 2010 Fanuc 18-T, Suggestions?
    By kend in forum Daewoo/Doosan
    Last Post: 09-19-2020, 09:58 AM
  4. CX-20 with U700 alarm
    By djackson854 in forum Waterjet General Topics
    Last Post: 02-22-2018, 05:28 AM
  5. Cutting 20 deg. Taper in Mits FA20s
    By Toolz in forum EDM Discussion General Topics
    Last Post: 10-20-2011, 12:29 PM
