601,652 active members*
2,467 visitors online*
Results 1 to 8 of 8
    Jul 2015
    5
    Mitsubishi FX10K - U700 error
    Hello!
    I have problem with Mitsubishi FX10K from 2001, on pressing ready button U700 error is appearing.
    I have found out that BKO-R8784 give only 240V, 150V only appear for 1s and fade to 0v after power is turned on and off.
    What can cause this problem? Is there any solution?
    Jul 2015
    5
    Re: Mitsubishi FX10K - U700 error
    Problem was power supply controling board, one of resistor solder path near connector to power supply was broken.
    Quote Originally Posted by 4d53 View Post
    I also have an FX 20K wire erosion machine. U700 gives wrong PWR SUP error. Could it be the same problem as yours? Can you help me. Can you send a photo of where this card is? I would really appreciate if you can help.
    Jan 2017
    3
    What did you find the issue?
    Oct 2023
    I had same problem do You find a solution?
    Jan 2017
    3
    Quote Originally Posted by biciu123 View Post
    I thought I had it fixed originally found a bad cooling fan on the top of the electrical cabinet. I was told by Mitsubishi that a bad fan can be an issue and cause the alarm. Although the alarm just came back so it's more than just that and I'm working through it with Mitsubishi now. Did you check the fuses I was told that that can also give that alarm.
    Oct 2023
    Yes I checked fuses, look good. The man who create this thread said that problem was power supply controling board - You know maybe what is the name of this board? how it looks like?
    Jan 2017
    3
    For me the u700 alarm started with 1 bad cooling fan on top of the electrical cabinet. I replaced it now a few weeks later the alarm came back. After many test guided by Mitsubishi support. I asked how many cooling fans are in the unit. Answer 13 I had only originally found 6 fans. It turned
    out a fan above the CPU started to go bad. Once replaced the alarm is gone.
  1. Mitsubishi fx10k
    By thunt481 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-27-2018, 03:39 PM
  2. Mitsubishi FX10K Pitch error parameter help
    By KMcorv22 in forum EDM Discussion General Topics
    Last Post: 05-06-2014, 12:07 AM
  3. mitsubishi fx10k chiller
    By moldman3 in forum EDM Discussion General Topics
    Last Post: 09-21-2011, 10:39 PM
  4. Mitsubishi FX10k vs. Charmilles 310 wire EDM
    By Alanstr in forum EDM Discussion General Topics
    Last Post: 04-20-2010, 07:51 PM
