549,879 active members*
2,321 visitors online*
    Dec 2021
    Mitsui Seiki VS3F Fault 0076
    Hello.
    We have a PC Alarm 0076 (swing arm count miss alarm) error on our VS3F machining center equipped with Fanuc OM.
    All axis movements are blocked.
    This message happened after the repair of a hydraulic cylinder in the tool magazine.
    The tool magazine is in the reference position as well as the atc arm.
    Is there a procedure to reset the ATC Counter?
    Thank you.
    Dec 2021
    Re: Mitsui Seiki VS3F Fault 0076
    I am also having this problem. hope someone can help. Thank you for having the same opinion as me
    Spider Solitaire 2 Suit
