531,697 active members*
3,833 visitors online*
Results 1 to 4 of 4
    Nov 2015
    205
    Mk3 OUTPUT connector fpr Arduino?
    Hello.
    Is it possible to convert the PWM signal from pin 1, 2 or 6 per capacitor into a 5 V signal?
    Can the + 5v pin from the outout connector be used to power an Arduino?
    Feb 2011
    69
    Re: Mk3 OUTPUT connector fpr Arduino?
    For pin 6 can be done, whileI have add minor electronic for controling rpm of spindle and goes from 0 to 10V.
    For power supply I am not shure because some ardu's can draw more current...
    Apr 2016
    5
    what minor additional electronics did you add for rpm control? My output board is not generating 0-10 volts. 0-0.3 is what I am getting. Pin 6 on pwm with a lagging volt meter does generate 0-4.9+ volts.
    Feb 2011
    69
    A friend of mine made for me and is something like this but without releys. Input is 12V from PS for MB
  1. OP connector sanyo denki servo PV drive - looking for connector
    By gm276 in forum Want To Buy...Need help!
    Last Post: 12-15-2018, 07:39 PM
  2. Output voltage from Output Board seems to be quite low?
    By cdfleischmann in forum PlanetCNC
    Last Post: 07-25-2018, 12:18 PM
  3. Poor output from Arduino CNC Shield v3
    By mike0866 in forum Arduino
    Last Post: 10-13-2015, 06:46 AM
  4. What is this connector?
    By vickson in forum Controller Cards
    Last Post: 06-21-2012, 09:26 AM
