584,817 active members*
4,613 visitors online*
    Jul 2020
    Question Morara Grinding : Part Origin Missing Alarm
    Hello,
    Can you please help in resolving the below issue:
    Machine: Morara Grinding machine - OD/ID grinding can be done in this machine.
    During new part setup for OD grinding, the grinding operator will take diamond(dresser) origin & Part Origin, after the sequence is over, when he start the cycle - the machine will stop with " Part Origin Missing" alarm. Tried doing part origin again & again, but same alarm repeats.
    But if you the NC file (machine run with Siemens 840d sl) - the alarm will go off, not sure how it goes off. But it will repeat again after one month or 20 days. Again i will load NC file.
    Not sure why it happens. Pls help in resolving.
    Jul 2020
    Re: Morara Grinding : Part Origin Missing Alarm
    Hello,
    But if load the NC file (machine run with Siemens 840d sl) - the alarm will go off, not sure how it goes off. But it will repeat again after one month or 20 days. Again i will load NC file.
  1. Setting a part's origin MasterCam X5
    By sklemp in forum Mastercam
    Last Post: 01-06-2012, 07:03 PM
  2. Moving Part Origin
    By eliot15 in forum GibbsCAM
    Last Post: 08-07-2011, 09:02 PM
  3. Mastercam X2. Reset part origin.
    By bob1112 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-19-2008, 12:54 AM
  4. Mazak VTC-41 w/Mazatrol EIA - No Part Origin
    By lfdgonzalez in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-23-2007, 04:34 AM
  5. Move part origin
    By vertcnc in forum Solidworks
    Last Post: 11-06-2005, 09:15 PM
