547,049 active members*
2,581 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Morbidelli author 503 retrofit for door frames
    Jul 2014
    Congratulations to all!
    We are engaged in the restoration of the Italian Morbidelli Author 503 1997. for cutting of door frames
    To date, the following has been done:
    1. Customized Drive (Yaskawa)
    2. MACH3 control program
    3. CSMIO -IP / A controller
    4. Number of additional I/O modules CSMIO-IO - 4pcs
    5. Partially written plugin for machine control https://youtu.be/P4YDF4_hjEY
    6. Some comments on the algorithms of the plugin https://youtu.be/-JmDyJRcUBw
    7. We are currently working on the clamps https://youtu.be/jczLTzvCl9Q
    8. Fix/find travers https://youtu.be/23gBTHePuSA
    Maybe someone will have comments on my work, after watching the video, write. Constructive criticism is appropriate
    p.s. My English is bad. But I will try
    Jul 2014
    Re: Morbidelli author 503 retrofit for door frames
  1. Tria 7500 for Morbidelli Author 503
    By stoned in forum Controller & Computer Solutions
    Last Post: 01-08-2021, 08:47 PM
  2. Morbidelli Author 503
    By almakaas in forum CNC Machining Centers
    Last Post: 12-27-2020, 02:57 PM
  3. Morbidelli Author 503
    By num1040 in forum CNC Machining Centers
    Last Post: 07-22-2018, 10:49 AM
  4. Need Postprocessor for Morbidelli author 503
    By carfreak in forum Post Processors
    Last Post: 06-21-2016, 08:51 PM
  5. Software para Morbidelli Author 503
    By neptunet in forum Uncategorised CAM Discussion
    Last Post: 04-04-2013, 03:23 PM
