600,838 active members*
3,285 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Mori NV5000 lost X,Y,Z,W zero reference
Results 1 to 6 of 6
    Jun 2007
    44
    Hi
    one of our Mori Seiki NV5000 mill with Fanuc 18i controller lost X,Y,Z,W(tool changer) zero reference position. I need instruction on zero referencing.
    Feb 2007
    464
    What did you do to lose the reference positions?It's easier to help if you know what caused it.
    Jun 2007
    44
    Replaced battery and wasn't connected correctly. Didn't loose any parameter just the zero reference position.
    Feb 2007
    464
    So nothing happens when you try to "home" it?
    Can you run XYZ manually?With the hand wheel?
    Aug 2007
    21
    Mori Seiki Engineer
    PLS CALL SERVICE CALL CENTER ASK THEM THE PROCEDURE TO DO THIS JOB(THEY HAVE PEPER LIKE I HAVE BUT MANY MANY PAGES). THEY HAVE QUITE ALOT MANY POINTS COMPLICATED, ESPECIALLY W AXIS AND Z AXIS IF YOU DO WRONG POSITION IT EASY TO CLASH A TOOL AND SPINDLE. AND YOU NEED TO CHANGE SOME PC PARAMETER TO MAKE W ZRN. I THINK THEY CAN HELP YOU IF CAN NOT GET FROM THEM EMAIL ME AT [email protected].
    THANKS.
    Nov 2024
    Re: Mori Seiki Engineer
    mori seiki model nv5000/40 vmc problem in software
  1. Scripting reference...
    By kiwichris in forum NCPlot G-Code editor / backplotter
    Last Post: 11-15-2007, 10:36 PM
  2. Good GD&T reference?
    By pkelecy in forum Mechanical Calculations/Engineering Design
    Last Post: 11-04-2006, 01:57 PM
  3. Reference positions in DIY CNC
    By davidp in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-23-2006, 08:48 PM
  4. Threading Reference
    By jlv3901 in forum MetalWork Discussion
    Last Post: 10-31-2005, 09:49 PM
  5. Programming Reference
    By jhwatts in forum MetalWork Discussion
    Last Post: 10-19-2005, 08:37 AM
