540,707 active members*
6,844 visitors online*
Results 1 to 1 of 1
    Mar 2021
    Mori Seiki LL8 With MSC-501
    Please help,
    I was tasked with the job to replace the X axis ball screw on a Mori Seiki LL8 after an incident. I was informed that nothing special was required prior to disassembling prior removal of motor and encoder. The screw has been replaced and reassembled. I have now powered up and driven to the ref position with no procedure for saving this as ref position.
    Feb 2021
    4
    Re: Mori Seiki LL8 With MSC-501
    Parameter 1815. Set APZ for x axis from 1 to 0 and back to 1. After restart controler. Then you saved actual pos as zero pos.
