537,606 active members*
3,692 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > mori seiki mapps msg 501 program edit!!!
    Feb 2020
    Unhappy mori seiki mapps msg 501 program edit!!!
    Hello engineers. PLZ HELP!!!
    We have a Mori Siki nv5000 machine with controller fanuc 18i - mapps msg-501.
    When we want to edit or add a program. system say error "EDITION IMPOSS"
    PANEL key-switch in edit position and screen in edit mode .
    Does anyone have a mapps operation manual or mapps parameters manual?
    Oct 2007
    69
    Re: mori seiki mapps msg 501 program edit!!!
    Are you still having this problem? Do you get any alarm number prior to the message.....ie EXnnnn code before the message?
    Feb 2021
    Hello Antipak,
    Do you have on the controler a button with GOP PARAM ?
    If you have it push it and on the screen there will be a key above PROGRAMM / OFFSET / PARAM MAKRO
    Push the buttom PROGRAMM and the key needs to go OFF.
    Hope I could help.
    Grtz Tom
  1. Mori Seiki SL2 damping program
    By Marik1 in forum Mori Seiki lathes
    Last Post: 01-28-2014, 04:34 PM
  2. Mori Seiki ZL-253 program setup
    By MGood in forum Fanuc
    Last Post: 08-30-2011, 10:59 AM
  3. MAPPS Parameters for a Mori Seiki NL
    By tminnig in forum Fanuc
    Last Post: 09-30-2008, 10:57 PM
  4. Mori Seiki Sub program
    By adaptaflex in forum Fanuc
    Last Post: 06-20-2006, 10:03 AM
  5. Mori Seiki Sub program
    Last Post: 06-19-2006, 02:59 PM
