Hello good people.
I have upcoming project that requires me to run a moulding cutter in my main spindle to cut a chunky bead around some solid timber (oak).
Cutter tool is with custom ground inserts (removable), 86mm diameter body, 20mm shank.
I've never tried this, no idea what methods are used in running this beast in solid wood. Speeds, Passes , etc.
Machine is SCM Author 430s, Xilog/Genio.
I doubt very much i can go slow full depth cut (oak panel 42mm thick, about 15mm into the part edge, 1000mm radius 180deg arc). Thrown into the deep end with this...
Any advice is appreciated.
Cutter tool diagram (ignore insert, its a bit different)
