562,566 active members*
3,212 visitors online*
    Sep 2007
    39
    MPX 200i tap cycle
    Hello all,
    I am looking for any info on the code specific to the MXP 200i fanuc tap cycle. Dropping the inquiry here while I search online and in online manuals. Of course, our shop lost the manual. Thank for any help!!!
    Dec 2012
    384
    Re: MPX 200i tap cycle
    I assume you have a YCM, on my MXP-100i it is something like:
    Alert >>>> Metric example for rigid tapping with a M10 x 1.5 metric tap !!!!!!
    G95 ( MM/REV )
    M29 S300
    G84 Z-20. R3. F1.5
    G80
    G94 ( BACK TO MM/MIN )
    - or
    G94( MM/MIN )
    M29 S300
    G84 Z-20. R3. F450. ( F=300X1.5 )
    G80
    - or G120 P1 cycle for Bolt Hole Circle Pattern for Drilling (G73-G81) or Tapping (G84):
    G94( MM/MIN)
    M29 S300
    G84 Z-20. R3. F450. K0 ( F=300X1.5 )
    G120 P1 X0. Y0. D100. A0. K6
    G80
    ( P1 = BOLT HOLE CIRCLE )
    ( X,Y = CIRCLE CENTRE )
    ( D = CIRCLE DIAMETER )
    ( A = FIRST ANGLE )
    ( K = NUMBER OF HOLES )
  1. tap cycle
    By tosetoe in forum GibbsCAM
    Last Post: 09-18-2017, 04:23 AM
  2. tap cycle HAAS m2
    By jbcj in forum BobCad-Cam
    Last Post: 02-10-2013, 07:27 PM
  3. Floating Tap Cycle
    By eartaker in forum Mastercam
    Last Post: 01-25-2011, 04:15 AM
  4. 0i-MC feedrate is ignored after a tap cycle
    By jhartleyjr in forum Fanuc
    Last Post: 06-28-2009, 01:07 AM
  5. lathe tap cycle example
    By metlshpr in forum G-Code Programing
    Last Post: 05-11-2009, 11:39 PM
