538,148 active members*
2,687 visitors online*
Results 1 to 6 of 6
    Aug 2008
    3
    MultiCam 3000 Xa servo drive motor
    We have a problem with the Xa servo drive motor shuddering during movement and when we dismounted it, found the pinion gear to be worn. Does anyone have a contact for getting a replacement gear, servo motor, or entire drive unit? Our experience contacting MultiCam hasn't had a great response and our machine is down. Any help would be appreciated.
    Jun 2010
    444
    Re: MultiCam 3000 Xa servo drive motor
    Does the gear spur have
    22 teeth
    22mm bore
    If so I have them for 75.00 usd ea. while you are replacing them you should replace all of them at the same time. There are 3 total, before you take the old ones off, check the measurement of the old pinion, match the measurement when you install the new one.
    Let me know if these are the ones you need.
    Jun 2010
    444
    correction to the post above
    25 teeth
    22 MM bore
    Aug 2008
    3
    That is exactly the ones I need! How may I contact you?
    Jun 2010
    444
    Give me a call...678-548-1483
    Maurice
    I normally ship Fedex the shipping cost ranges from 25 for ground, 55 for international priority.
    Jun 2006
    198
    What size and pitch are the pinions for the 3000 series???
  1. Multicam 3000 motor fault (0X 13)
    By murfeedean in forum Multicam Machines
    Last Post: 11-22-2013, 09:36 PM
  2. Multicam 3000 - Motor Fault 17
    By jameshoy in forum Multicam Machines
    Last Post: 07-15-2013, 04:55 PM
  3. multicam 3000 motor fault
    By polystone in forum Multicam Machines
    Last Post: 12-11-2012, 07:28 PM
  4. servo error - MULTICAM 3000
    By ugan.git in forum Commercial CNC Wood Routers
    Last Post: 04-04-2012, 04:12 PM
  5. Multicam 3000 stepper motor
    By zsteve in forum Commercial CNC Wood Routers
    Last Post: 12-23-2009, 05:51 PM
