586,009 active members*
4,913 visitors online*
    Question MultiCAM-MT510
    The lifting cable (front right) is broken.
    Most likely wear and tear.
    It was decided to replace not only this cable, but also the left one.
    The central one was not changed.
    The replacement procedure was not easy.
    There were many unsuccessful attempts.
    Finally, the left cable was replaced.
    With two cables they began to check the machine.
    After turning on the machine and starting Find Home, when the table moves along X at the very end, there is a sharp knock and stop
    System Interupt: X Home
    I ask for help.
    Jun 2010
    463
    Re: MultiCAM-MT510
    Lifting Cable....you might want to upload some picture on the site here to give better idea of what you are talking about
  1. Need Help with MultiCAM
    By loyedp in forum Multicam Machines
    Last Post: 11-09-2021, 07:12 PM
  2. Need help with Multicam 44 Plus
    By grussell in forum Multicam Machines
    Last Post: 11-09-2016, 04:40 PM
  3. Multicam HELP? 3000 motor fault Multicam motor fault (0x 4
    By murfeedean in forum Multicam Machines
    Last Post: 11-05-2012, 02:22 PM
  4. Multicam CSG
    By BASiQ in forum Multicam Machines
    Last Post: 02-21-2012, 03:57 AM
  5. Multicam MG
    By Dropout in forum Commercial CNC Wood Routers
    Last Post: 10-18-2010, 08:26 PM
