544,151 active members*
1,607 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Multus B400W synchronizing spindles (M151)
    Jun 2021
    I am fairly new to the Multus world, that being said I am trying to do a pickoff from the main spindle to the sub. I need my sub jaws to line up in a certain area on my part. My question is how do I clock my C axis so that during transfer my jaws are located where I want them?
    Mar 2009
    1485
    Re: Multus B400W synchronizing spindles (M151)
    if both spindles equipped with orientation function ( C axis )
    Apr 2009
    1133
    There are parameters for both the M19 and the M151 relationships. The M151 is “ live” so that once active the spindle 1-2 parameter can be adjusted and you can watch it move as the parameter is adjusted. M19 should be listed in your spindle 1 parameters and M151 should be under spindle 1-2 parameters as a zero offset parameter.
    It is possible to use the C axes as well but it is not how it is intended to work. M151 is for that specific purpose. Once active, you can start, stop, jog, M19 while maintaining the phase angle.
    Note: One chuck must be open until the M151 is active then clamp is possible once phase is achieved.
  1. Advice solicited for synchronizing motion
    By drdonh in forum DIY CNC Router Table Machines
    Last Post: 02-10-2019, 04:53 PM
  2. synchronizing x axis
    By Goosey in forum Stepper Motors / Drives
    Last Post: 05-31-2017, 03:56 AM
  3. Synchronizing two motors in Mach 3
    By jeremyrockjock in forum Mach Software (ArtSoft software)
    Last Post: 10-24-2012, 11:34 PM
  4. Synchronizing Main and sub-spindle
    By TonyW in forum Okuma
    Last Post: 05-06-2011, 04:01 AM
  5. Replies: 10
    Last Post: 04-28-2010, 09:42 AM
