591,380 active members*
7,041 visitors online*
    Nov 2008
    96
    MV40E Axis Zero Procedure
    Hello,
    Anyone out there have the procedure to zero all three axis on a MV40E with Fanuc 21i Control?
    Tool change position and checking procedure as well?
    I have all three APC Alarms.
    Thanks!
    Re: MV40E Axis Zero Procedure
    Quote Originally Posted by JohnnyTurn View Post
    Hello,
    Thanks!
    APC alarm could be cable or encoder problem, but it is unlikely that all three axes have the same problem at the same time.
    Nov 2008
    96
    Quote Originally Posted by cncmakers001 View Post
    It's neither of those.
    Machine was fine. Sitting idle. Power outage made two internal breakers trip. Thus, cut power to the batteries.
    Servos lost position. I need the exact procedure.
    Saw it done 20 years ago. Yes, we have kept that original position for 20+ years. Batteries religiously changed on time.
    I am calling DMG Mori in the AM.
    Never dealt with them since the merger.
    I hear good things on them sending out these procedures.
    Thanks for the relpy.
  1. Fanuc 21M - MV40E DRO Updating but no movement
    By kingofl337 in forum Fanuc
    Last Post: 12-20-2023, 11:36 PM
  2. Mori Seiki MV40E with fanuc 21i control
    By paulk333 in forum Fanuc
    Last Post: 05-09-2022, 12:38 PM
  3. Y Axis Gib Adjustment Procedure
    By RTP_Burnsville in forum Tormach Personal CNC Mill
    Last Post: 12-14-2018, 07:33 PM
  4. MV40E Tool Pot Issue
    By JohnnyTurn in forum Mori Seiki Mills
    Last Post: 06-09-2009, 06:34 PM
  5. Mori seiki MV40E memory card problem
    By v.sundermoorthy in forum Mori Seiki Mills
    Last Post: 04-20-2009, 08:35 PM
