549,843 active members*
2,295 visitors online*
Results 1 to 5 of 5
    MX4660 and Delta VFD Wiring Help
    Hi All,
    I've owned an AvidCnc (Cncrouterparts) 4x4 machine for almost 5 years. Recently, after burning up my second router I decided that a spindle might be in my future. I happen to come across a guy selling a water cooled 2.2kw spindle setup that he just removed from an Avid machine due to an upgrade. Long story short, the price was right and I made the purchase. The spindle is a GMT and the VFD is a Delta VFD022M21A. The wiring (power and motor) are pretty straight forward. However, I am having trouble understanding the wiring between the vfd and my controller so I can control things through Mach3. I thought it would be pretty easy using the VFD schematic and MX4660 setup guide from Avid but I guess I was wrong. For one - the VFD schematic shows 6 wires while the controller guide shows 5. Also, I figured the wire colors would match but began to question myself on that assumption. What I am looking for is some help to cross reference the controller connections to those on the VFD.
    MX4660 EGND ------> VFD XXXXX
    MX4660 0-10V Out ------> VFD YYYYY
    MX4660 +10Vdc In ------> VFD ZZZZZ
    MX4660 Output 1- ------> VFD AAAAA
    MX4660 Output 1+ ------> VFD BBBBB
    What I need is help with is identifying XXXXX, YYYYYY, ZZZZZ, AAAAA and BBBBB
    I've included snapshots of the relevant info from the Avid Guides and the Delta VFD manual
    Thanks for your help!!
    Dan
    Jan 2012
    146
    Re: MX4660 and Delta VFD Wiring Help
    tapper00, you are treading where I dare not. If you aren't on good terms with the factory I would call a commercial electrician to do the wiring.
    Jun 2021
    26
    Have you had the opportunity to look at the pertinent sections of the MX4660 manual?
    http://www.leadshineusa.com/UploadFi...660hm_V1.1.pdf
    Perhaps something there will help - and apologies if you have already done so.
    Jan 2005
    13253
    Quote Originally Posted by trapper00 View Post
    Hi All,
    Dan
    It is quite a simple connection
    VFD Drive connections are
    MO to Ground for the Relay On / Off connection
    AVI & Ground for the 0-10v Speed control
    If you Control needs a 10v supply for the PWM then use AMF & Ground for the 10v supply, check that this VFD Drive output is 10v
    Mactec54
    Mactec54
    Thanks for the info. Appreciate the help.
    Dan
  1. MX4660 Estop wiring
    By TMToronto in forum Leadshine
    Last Post: 10-05-2021, 03:54 PM
  2. wiring spindle to mx4660
    By jlroch in forum Leadshine
    Last Post: 07-09-2020, 07:14 PM
  3. Need help wiring a PMDX 107 to a Delta VFD-M
    By Biill I in forum Spindles / VFD
    Last Post: 07-24-2016, 10:07 PM
  4. Need help wiring a PMDX 107 to a Delta VFD-M
    Last Post: 07-24-2016, 09:58 PM
  5. Replies: 1
    Last Post: 07-26-2014, 10:21 AM
