579,280 active members*
8,547 visitors online*
IndustryArena Forum > General Maintenance > SERVICE FOR CNC-MACHINES > My T200A Boring Machine spindle can't spin
    Excuse me, I Got problem my machine I checked inverter no error notification, but if i push button on UI it's won't spin.i push jog in remote inverter does, I push run from the remote nothing happens. Got ideas fellas ?
    Sep 2018
    Re: My T200A Boring Machine spindle can't spin
    Hi, what is the type of inverter? what is the control system?
    many time , when config of inverter is distant remote, local panel command does not enable... parameter inverter lost???
    check wiring command run or enable, take datasheet inverter and search for input run enable forward...etc
    it can be a relay charred, bad contact or many others things....good luck
  1. The spindle is noisy but does not spin!
    By Thomas91 in forum Chinese Machines
    Last Post: 03-06-2021, 10:14 PM
  2. Replies: 0
    Last Post: 02-24-2021, 06:06 AM
  3. Replies: 0
    Last Post: 07-29-2014, 11:56 AM
  4. Drilling through spindle coolant on Horizontal Boring Machine.
    By SatishNaik in forum News Announcements
    Last Post: 08-22-2013, 03:25 PM
  5. Replies: 2
    Last Post: 07-24-2013, 07:31 AM
