594,860 active members*
6,178 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > NC Program Upload Error/Network Connection Lost
Results 1 to 1 of 1
    Nov 2024
    7
    Exclamation NC Program Upload Error/Network Connection Lost
    I've been getting "A Socket Error occurred, Check the network connection to the Control" error message whenever I log in and open NC upload program on Front End PC.
    It started happening ever since we migrated network from HSSB to Ethernet.
    and symptom is the network configuration saved on NC upload program is wiped out (IP address, Port, connection type selection, etc.) and we are having to manually input everything back to set the connection again.
    Would anybody know what could be the reason for this issue?
    HELP NEEDED!!
    THANK YOU!!
    Re: NC Program Upload Error/Network Connection Lost
    Quote Originally Posted by alexkyi91 View Post
    HELP NEEDED!!
    THANK YOU!!
    There might be a conflict between old HSSB settings and the new Ethernet setup.
    For example, if the NC upload program is still trying to access the device via the old HSSB port settings, it might fail to connect and reset the saved configuration.
    Nov 2024
    7
    how would we be able to check to make sure it is tying to access via new ethernet set up? or change configuration so that it is trying to access via new ethernet set up?
    Thanks,
