585,973 active members*
4,020 visitors online*
Results 1 to 7 of 7
    Jul 2017
    NC Studio / Weihong PM53C5 DRIVERS
    Im having problems to install the PCI Card for the NC Studio
    It was already working but the Windows failed and we need to reinstall it
    afterwards the nc studio shows a message " Hardware FAILURE"
    Any advise
    Apr 2016
    12
    Re: NC Studio / Weihong PM53C5 DRIVERS
    Did you connected your hardware before installing the drivers? I had the same problem with the ncstudio card. I installed the cylinder drivers and it seems everything to be ok. Try this and try to install the software with the pc and the machine card connected.
    Cheers.
    Sent from my HTC Desire 620G dual sim using Tapatalk
    Mar 2018
    Dear Bro,
    Use Windows XP SP 2 instead of other operating system for your CNC machine.
    This will fix your problem.
    Thanks.
    Jun 2007
    8
    I have a very similar problem. It was all working well but the computer started having issues so I did a complete hard drive format and fresh install of Windows XP, then installed the controller card and NZStudio (version 8). Now the controller isn't sending a signal to the spinldle inverter or servo drivers, and unfortunately Service pack 2 didn't solve it. The software is working fine and there is movement on screen when I use the jog controllers, but nothing happening on the actual machine.
    Quote Originally Posted by gjokos View Post
    Cheers.
    Hi gjokos
    Windows failed and i needed to reinstall it. Now i can not connect to the card. Can you send me the cylinder driver? I hope this will solve my problem.
    Best regards
    Andreas
    Quote Originally Posted by ViktorEC View Post
    Any advise
    Hi ViktorEC. I now have the exact same problem. How did you solve it? Help would be much appreciated.
    Jul 2022
    5
    Before doing that, you should make backup of the configuration in your NC Studio, using NCHelper software, you can find it on NC Studio installation folder.
  1. Do You Know WEIHONG CNC Controllers?
    By MsMary in forum Commercial CNC Wood Routers
    Last Post: 08-24-2022, 03:37 AM
  2. Weihong card
    By Roctech-Mercy in forum Roctech CNC Routers
    Last Post: 08-26-2015, 09:08 AM
  3. weihong nk300b
    By chinojar in forum ArtCam Pro
    Last Post: 05-03-2015, 09:44 PM
  4. Dsp or Weihong nc studio for cnc router 3d jobs
    By M.Abid in forum Techno CNC
    Last Post: 01-03-2015, 04:07 PM
  5. Weihong OS
    By Chris Zenda in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-03-2008, 02:35 PM
