544,218 active members*
2,804 visitors online*
Results 1 to 11 of 11
    Gold Member
    Jan 2007
    1801
    NCstudio 4.XXX and 5.XXX
    last year I purchased a Chinese router with ncstudio.
    my first impress with ncstudio and failed installation trials made me I might shift to mach3
    I got eventually help and installed ncstudio and today im glad I using it..
    in this topic I would like ot give I collected within a year about this control..
    first off
    the version 4.XXX and version 5.XXX is not fully weihong, tough it is weihong design..
    the version 8.XXX owners can get serious help from weihong, or naiky..
    why is ncstudio interesting?
    type into google pci controlcard, or pci control..
    youll find this type control start from 1000 dollar at least.. so if you can buy a similar for 50 dollar, then I think it worth to take a look what is it...
    http://kediao.en.alibaba.com/product...c_machine.html
    let start at installation
    most important, DO NOT PUT CARD into computer BEFORE installing ncstudio..
    within you install program it will put a *.sys named driver into windows/system32 folder
    after installing ncstudio, TURN OFF computer
    install physically the card, and turn on computer..
    now windows found new hardware, and recommend automatic install.. do not accept,
    look for the folder ncstudio installed, likely program/files/weihong/ncstudio 5.56
    then windows will find the proper driver install it and ready
    Gold Member
    Jan 2007
    1801
    next steps
    now
    ncstudio run and next is calibration..
    you will seeing tabs somewhere left as,,,, Trace Log Manager Parameter I/O state
    first click I/o state
    simplified, if you seeing gren colored title and marked differently as "N" then right click on the title like X axis together with shift-ctrl-alt keys pressed and hold...
    a little menu will coming up and you set state reverse
    program will notify you after restart ncstudio state will be valid
    after all title , calibration, xaxis,yaxis,zaxis, spindle 1-2-3 set to right state you restart ncstudio
    next step to setting steps properly
    I show here only for ballscrews... because for gears too many different and those machines likely coming with dsp handheld control.
    there are two settings known
    very generally, for nema 34 motors 10 mm leadscrews
    for nema 23 motors 5 mm leadscrews
    so you need to set for 5 mm lead 0.003125 value
    or for 10 mm lead 0.00625 value
    (if you have gears, rack n pinion, the they are different settings)
    in same place you can set yet,
    start-end mechanical cordinatas.. its your workenvelope or max movement on router on all axis.. set proper values
    start up federate... this is when machine axis from steady state will start..
    you can set it to zero... that will work for everything..
    for ""3dcuts"" I meaning reliefs where you have million small segments unorganized, then you can set startup federate for a small value likely 40-50 mm
    be careful set this to higher value because that's mean motor has no time to accelerating and it will lead lost steps..
    set Z axis max speed it is experimental and you find the proper value..
    mine is set to 3000 mm per min
    linear acceleration... this is likely when vector start and router need to run up, or ramp speed up..
    150-200 a good value
    later you can make experiments and set higher or lower
    connection acceleration... this when machine already in moment and got to a point between vectors.. this value you can set higher, 500 and up
    with experiment you can find the proper setting..
    spindle ... most spindle up to 24K some of 18K max rpm... set proper value
    for delay to waiting for spindle run up or slow down you can use 5000 millisecond value
    after these close this menu tab and go to machining tab
    Gold Member
    Jan 2007
    1801
    pdf for settings
    this pdf I found on net and about settings
    youtube also has by salecnc and jcut too many videos
    Gold Member
    Jan 2007
    1801
    homing function, tool zero function
    after you get trough successfully installing bcstudio, let see some functions
    first homing..
    it called moving to reference points..
    see attached picture.. when you perform it, machine will going slowly to limitswithches and reversing a few mmm..
    very accurate, however not suggested to using as absolut zero..
    also, if workenvelope correctly set , work cordinatas, then program will automatically slow down to zero when axis reaching hardware or soft limit..
    very intelligent program..
    also when you ask dry run, simulation of run program warning if gcode were run outside of limits, even a chart coming up showing what axis and on what end were out of limit..
    toolzeroing... program calls it, mobile calibrator.. guessing you have a given thickness a toolzeroplate.. it can be even a piece of aluminum ductape sticking onto surface..
    theres a very helpful post on cnczone..
    http://www.cnczone.com/forums/chines...achines-2.html
    when you perform it machine Z will going slowly about 60 mm per min downward till reach toolzeroplate and reversing to a preset value, and set the zero on Z
    a little remark here a well grounded machine need only one wire from #pin 1 ... however recommended to using two wire #1 pin and a ground from the break out board..
    there are several type on the market I posting two of them
    one more thing..
    when axis moving out by any reason outside of limit, a red circle will be visible around left top.. and machine can not be moved..
    then you click on ""turn off mechanical limits" ... youll get a small info window and you can use the manual jog buttons..
    Dear Victorofga,
    I have an issue with my pci card and NC studio. I mistakenly put the card before installing NC Studio (For not reading the forum earlier). Now there is the following error:
    "Hardware failure. Please close the application then check the hardware".
    I was thinking the solution will be to uninstall the software, take out the card, and erase the card's driver (i do not know how to erase the driver). And do the whole proccess again. Your suggestions please.
    Bests,
    DT
    Oct 2014
    Re: NCstudio 4.XXX and 5.XXX
    hellow dear
    i have cnc router jdz-1325 and i lost the parameter of the cnc machine ,,please can you help me i need to send the parameter which are suitable for this machine ,this is the pAttachment 260122cture of the machine: Attachment 260122
    Gold Member
    Jan 2007
    1801
    what you mean as parameters?
    first homing machine, then carefully move to the ends on the 3 axis.. when it ""bumps"" move back a few mm, and set those dimensions to machine limit..
    spindle delay mine is 5000 this is the value router waiting for, spindle accelerate up
    feed
    this is hard to describe, it variable machine by machine..
    set startspeed to zero first,
    linear acceleration about 120
    and connection acceleration about 300
    now.. after tests, you can try to set start to a low value 20-50 so machine never stops really
    linear acceleration important, because this is what causing ""jerking"" on small segments..
    I never could set over 180
    connection acceleration is when machine in motion, and changing direction between vectors, that are connected..
    this can be up to 1000
    but again, these values are working for me..
    for you might different working..
    start with low values and gradually change them to higher..
    very generally.... as you raise feed, abd it start to stalling, then you set back about 30 percent..
    that is the safe max speed and acceleration..
    Jan 2015
    6
    Hi
    This forum seems very helpful. I fired up our new SUKE 1325 CNC Router for first time today. Upon launching NC Studio (ver 5.5.60) I was greeted with errors. BKREF ESTOP LIMIT ALARM. I went through the manual and adjusted all parameters as listed. restarted software, same errors. Checked all connections, they were fine. Still got errors. I disabled mechanical limits through operations menu and errors cleared. Researched on web, made a few adjustments, restarted still got errors. Any ideas? All help is appreciated. Thanks
    GregClick image for larger version.
    Junior Member
    Jul 2014
    Hi Davidtobat
    I have the same problem I tried a restore point which did not work how did you solve this
    George
    Apr 2015
    Quote Originally Posted by davidtobar View Post
    Dear Victorofga,
    Bests,
    DT
    no problem if you instal ncs befor you put your card
    this not problem
    every chines machine they send ncs softwear / driver / type 3 or artcam
    in the driver there is a file you have to remove it from driver fille and instal the driver manuel
    instal befor or after ncs no problem
    i try this last days
    Feb 2012
    hi,
    can someone help me. just i installed nc studio 5.5.60 and it is asking me for registration code. what shall i do. you help is much appreciated.
  1. ncstudio
    By jalal aw in forum Commercial CNC Wood Routers
    Last Post: 05-05-2014, 07:30 AM
  2. NcStudio help
    By Dhashna in forum Chinese Machines
    Last Post: 11-26-2013, 08:34 PM
  3. Ncstudio help
    By bachaar in forum Chinese Machines
    Last Post: 02-24-2013, 09:04 PM
  4. NcStudio V5.5.60.0 HELP!!
    By Memoir in forum Community Club House
    Last Post: 09-30-2010, 07:16 AM
  5. ARTCAM MMG. TO NCSTUDIO
    By Ironmaster in forum CNC Wood Router Project Log
    Last Post: 08-11-2010, 07:18 PM
