Good Morning.
I found this on the web. My machine has the automatic sensor for the Z.
Does anyone know if it's possible to put this doing the 3 axes in NcStudio?
Good Morning.
its pending on what ncstudio you have
if you have the original, then weihong helps you
if you have the clone version then your simples solution is touching the 4 side and using calculator figuring the center
are you working with wood or you making metal parts?
if version is 5.5 or 5.6 or 5.4 then its clone
not much less from original
if you need exact position then just hold down some stops made out of scraps then mill them
then your part is on exact position..
99 percent of jobs you going to cut the outer edges too
so not critical the position to 0.01 mm
actually theres some programming guide a pdf by weihong
it made in 2013.. I cant find link right now
also on the disc you could find a text file describing functions trough on G and M codes
honestly I think I have the original.
I had to see the board that I have in the pc has the welong writing.
Enviado do meu iPhone usando o Tapatalk
no, it is not the clone card
indeed its an expenses card
https://www.aliexpress.com/item/3-ax...719370039.html
just don't run to change because you don't get better control
heres an email I have
Support_weihong@188.com
heres a pdf for your control
http://www.weihong.com.cn/en/uploads...60Q6110323.pdf
if you opened pdf, you can see on your control theres a toolsensor terminal
this pdf, for the ncstudio V10 describes how you can use the
in the 3.2.3 chapter describes how you can set rough values as parameters to using the gadget originally you posted
http://www.weihong.com.cn/en/uploads...160Q6111H8.pdf
Thanks for the answer.
I'll try to study this a bit and see if I can do anything.
Already tried to contact weihong, for another problem.
But they did not support it.
They told me to go and talk to whoever sold me the machine.
So you're saying that I can install the V10 version of NcSudio?
I'm using the V8.
well
what you mean try to study a bit?
if you don't read the manual, then you wont figure it out..
when did you buy this machine?
what machine is it?
have you ever read the manual?
weihong has the V8 and V10 uploaded on their site
you better off follow the manual, that says what version can be installed..
I know what I were do.. but I can not tell you install it..
the V10 manual says V10 works with your card, but I didn't say you have to install it
the V8 also has the auto centering function
see 45 page
http://weihong.com.cn/en/uploads/sof...60Q6111540.pdf
if you don't do your home work, then no one can help..
what I am sure, if I ever add 4th axis or ATC I going to use either way weihong or syntec control..
I know you did not tell me to install the V10. I asked if I could?
I bought my machine in china. Chinese manuals are very limited.
I'm learning by the way. And with the help of people like you who help me in the forums.
This is my machine:
https://www.cncrouter-shop.com/pro/2...r-door-making/
The card is the same, but the Lambada is weaker.
Mine is the Lambada 3L.
you got a great machine
I know people bought from blue elephant and they like it
the program associated with the card you have in the computer
trough on pci bus is very reliable
this is the version 8 docu..
I firmly believe the version ten should be ok, but I can not tell you go ahead and install..
I think very minimal the real difference between V8 and V10
the links I posted, please download the PDFs and really jump on and start to read them
very important don't try to set what they were set...
for the original question theres the option to install an auto zero..
but I think first try to use stops to align parts..
its safer and I think faster
either way use the popup pins if they installed or screw down on the spoilboard scrap pieces and mill to a known measurement..
by the way
what kind of job you plan to do with the machine?
my friend has a shop , and he makes doors windows to the 63 or the 68 mm standard..
but he purchased an Italian door-window machine..
do you have hand wheel for the machine?
I just asking because I don't see plugged in into control
I do not have.
when it was negotiated it was to have. but then there was a mistake from them and it did not work.
made a discount.
I'm sorry I do not have it.
I want to make hurricanes for hinges on the doors and other things.
first try to get a pendant
this is a very large sized machine to jogging and setting up from several meters distance
what is good thing, the Z axis sufficiently large if you need a horizontal spindle.. for working on doorslab edges like milling in the lock..
and again, download the PDFs and realy get learning it..
mechanically machine is good, and I think the control itself not less or worse from other controls..
so you need to get working the machine and producing some income with
im started with turbocnc, then mach3 then ncstudio
if I were have to back, I would choose turbocnc over mach3, altought that was lacking the continuous velocity..
