Hi.
Need a disk machine for cutting rubber (circular).
It is necessary to cut hard already vulcanized rubber with aluminum inserts. Products up to 540 mm wide, up to 250 mm high, up to 1500 mm long. The hardness of rubber is 1.14. At the moment we are sawing with a band saw, but the saw is constantly moving away. We are looking for a solution for a machine with a disk
