589,273 active members*
6,830 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > CITIZEN Machines > Need Citizen L20 5-Axis Parameters for Mitsubishi Medlas 300
Results 1 to 11 of 11
    Feb 2019
    14
    Post Need Citizen L20 5-Axis Parameters for Mitsubishi Medlas 300
    Hi.. I have initialized the machine and also have the hard copy of the parameters, I however I need the initial machine Parameters for starting the machine screen to be able to feed in the others. Basically I need the soft copy of the parameters. If anyone having this would be a great help.my email is [email protected] kindly contact me if you can help... Regards
    Feb 2010
    31
    Re: Need Citizen L20 5-Axis Parameters for Mitsubishi Medlas 300
    Hi
    You still need those parameters, or you solved the problem?
    Do you have other types of Citizen, such as Cincom Citizen L20 Meldas 600?
    May 2003
    130
    Did you get this fixed?
    Jul 2019
    53
    I have a parameter of citizen m32 meldas 600 I have a citizen m32 2001 cnc machine problem on C axis when I start the program stops blocked on M18 C0 even on MDI it does not work there is no alarm nothing
    Feb 2010
    31
    Hello
    What it means is not working?!
    The machine does nothing, or the spindle rotates slowly and does not stop at C0?!
    Did you set the parameters again, or just didn't want to do C0 anymore.
    Do you have the Macro program for the C axis in the machine?
    If you do not have the macro for the C axis in the machine, it will not do anything that refers to that axis, it will simply stay in place without any alarm.
    Jul 2019
    53
    the machine works normally until milling It remains stuck on m18 c0 When I touch the spindle. With the hand it is fixed after I After I click on the rest button and I start again the axis c it does not work on the two spindles on MDi What I will do
    Feb 2010
    31
    Hi
    If the machine does C0 but stops after, it may not like something in the program, check at least 10 lines of program after M18C0.
    Usually if it does not give an alarm it has a problem with the program or a sensor that is not made and does not have timer in the PLC to generate an alarm.
    Unfortunately your English is not very good and I do not understand very well what you are writing here.
    Maybe you can take some pictures, or even a movie.
    Jul 2019
    53
    Yes because I speak in French that's why hhhhh my English is finish Can't download the images on this site you can give me your e-mail and I send you the photos
    Feb 2010
    31
    Jul 2019
    53
    it works from then always on rear spindle my on the main spindle it does not work I have the problem just on the main spindle
    Mar 2024
    4
    Did you have parameter list for CITIZEN L20 1994y.
    [email protected] Mitsubishi meldas 300
