541,080 active members*
3,142 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > Need electrical schematics for Maho MH 800 C
Results 1 to 8 of 8
    Jun 2009
    4
    Good day everyone,
    My name is Volodymyr. I got a secondhand MAHO MH 800 C (CNC 432)
    I am need of the electrical schematic diagram of this machine.
    If anyone has a soft-copy (pdf, image file) of the schematics then please send me a copy to my email: spec-cnc@ukr.net.
    If there is a link where to get the scheme
    I would be very grateful if you could.
    Best regards,
    Volodymyr
    Mar 2007
    64
    Re: Need electrical schematics for Maho MH 800 C
    Did you get the electrical schematics you needed? I have an 800C 4 axis (baxis) NO tool changer. Swivel head NOT M code programmable for the swivel.
    My machine is a 1986.
    If I can help you out let me know......I'll have to scan my schematics but I'll do that if you need them.
    Whats the problem with your machine?
    Jun 2009
    4
    Hello cncmm!
    Many thanks that have responded
    WOW
    I already did not expect someone to answer.
    I thought to draw from the machine.
    I did not receive any electrical schematics on the machine.
    I have a machine without a tool change.
    Three axes + turntable.
    I will install a new CNC system SIEMENS on the machine.
    The drives will remain.
    For this, I need diagrams.
    I do not have information on the PHILIPS linear encoders.
    You can use them or not.
    We need a TTL signal from the encoders.
    Best regards,
    VolodymyrClick image for larger version.
    Mar 2007
    64
    Give me a couple of days and I'll scan my schems for you.
    I have to ask; Why do you want to change to a Siemens control? I have two DMG 103V's with Siemens controls and I like the Phillips, Heidenhain controls MUCH more.
    Jun 2009
    4
    Thank you.
    There are a number of machines already on Siemens both on new and old systems.
    The machine operator, who knows how to work with PHILIPS, is hard to find.
    Operators who work with SIEMENS already exist.
    Another important aspect, there are no specialists in repair and maintenance of PHILIPS.
    There is no documentation on the CNC.
    Well PHILIPS occurs rarely in our country.
    First, the rotary table encoder broke.
    Replaced. Does not work.
    The board was replaced in the CNC.
    Now the machine does not work two axes.
    So came to the decision to change the CNC.
    I also like the HEIDENHAIN but the price is more expensive than Siemens.
    Mar 2007
    64
    Did you receive the Drop box link I sent you to the electrical schematics ???????
    Jun 2009
    4
    Thank you
    I downloaded the file.
    May 2018
    do you have MH800E?
    i need electrical wiring of it.
  1. Looking for ZL-200 Electrical schematics manual
    By Iownacnc in forum Mori Seiki lathes
    Last Post: 07-31-2013, 02:02 AM
  2. Preliminary electrical schematics
    By ceencee in forum General CNC Machine Related Electronics
    Last Post: 06-04-2011, 03:44 AM
  3. mori sl-1 lx-1 electrical schematics
    By machineryaxis in forum Mori Seiki lathes
    Last Post: 08-10-2009, 03:31 PM
